Tomas Posted February 22, 2021 Share Posted February 22, 2021 Hello Guzzi riders, Over the last weekend I washed my V11 Lemans while it was running. I checked the oil afterwards and found that it was full of water. I flushed the oil system 4 times with fresh oil and feel like I'm back to square one. Expensive oil change. The wash was with standard garden hose. I was careful to not spray top of engine, and tops of cylinders. I did gently rinse off throttle bodies. At no time did the bike loose RPM or stutter during the wash. Has anyone had their bike ingest water like this before? I hope that if I ride in the rain it will not ingest water. Tomas Grim San Jose, CA Link to comment
docc Posted February 22, 2021 Share Posted February 22, 2021 Welcome, Tomas! If the bike didn't stutter, the water did not enter through the intakes. The three places that come to mind to inspect are the crankcase vent hose at the rear/top of the engine, distributor block-off plate at the top-right of the engine inboard of the back of the right cylinder, and the dip stick. Let us know what you find! 1 Link to comment
Lucky Phil Posted February 22, 2021 Share Posted February 22, 2021 3 hours ago, Tomas said: Hello Guzzi riders, Over the last weekend I washed my V11 Lemans while it was running. I checked the oil afterwards and found that it was full of water. I flushed the oil system 4 times with fresh oil and feel like I'm back to square one. Expensive oil change. The wash was with standard garden hose. I was careful to not spray top of engine, and tops of cylinders. I did gently rinse off throttle bodies. At no time did the bike loose RPM or stutter during the wash. Has anyone had their bike ingest water like this before? I hope that if I ride in the rain it will not ingest water. Tomas Grim San Jose, CA What precisely does "full of water" mean? Ciao 1 Link to comment
KINDOY2 Posted February 22, 2021 Share Posted February 22, 2021 Like docc said..breather hose I bet! Link to comment
gstallons Posted February 23, 2021 Share Posted February 23, 2021 If you have never replaced the breather hose , inspect it & inspect it again , then replace it . MG cycle will give you the best price . 1 Link to comment
