Anyone able to post a pic of the steering damper?
Specifically, the rod end fixings where it attaches to the forks.
There are two dished washers. Do these go either side of the rod end ball?  I assume they cup the spherical bearing?
Thanks.
Thanks.
Yes they do correct.
7 hours ago, Steve S said:
The dished washers go the other way or the movement will be restricted
Nope, the whole idea is the movement is restricted so the damper unit doesn't flop around. It's just not restricted enough to stop it pivoting as it should when the steering is turned.
