fotoguzzi Posted March 21, 2021 Posted March 21, 2021 If I wanted bars instead of clip ons would a Centauro top triple clamp fit a V11?
Cabernet Posted March 21, 2021 Posted March 21, 2021 No need. On the underside of your top yoke there are the bosses ready to be drilled to take bars. I used Renthal CL003 bar mounts and an 828-50 Fatbar with bar ends and G176 grips. 1
Cabernet Posted March 21, 2021 Posted March 21, 2021 Oh, you'll also need some A06 spacers. You'll need to contact Renthal USA for them once you have proof of purchase of your CL003. 1
fotoguzzi Posted March 21, 2021 Author Posted March 21, 2021 I may want to keep the original stock and not drill it. So the next owner would have option to return to as it came from the factory. just thinking ahead, I don't even have the 01 Sport yet.. that in mind are there any luggage racks, bag mounts available? Also, is there a chance to find a Stucci type fairing?
paulnaz Posted March 21, 2021 Posted March 21, 2021 Hey Foto, Ballabio tree is the same but drilled for bars and all the associated hardware from a Cal stone will work. The previous owner of my 2000 Sport did this to mine. Paul B
fotoguzzi Posted March 21, 2021 Author Posted March 21, 2021 Paul, does that mean a triple clamp from an EV would also fit? I have a complete EV fork that I couldn't find a buyer for so can take that off.
paulnaz Posted March 21, 2021 Posted March 21, 2021 Part No. on the tree on mine 01493180. Part No. for the EV 03493100 so I dont know if the fork spacing, diameter is the same. The handlebar support hardware will work though,with the Ballabio tree. Paul B
docc Posted March 21, 2021 Posted March 21, 2021 I didn't think any EV has "upside down forks"/ male sliders at the bottom. So, I can't see how EV triples could work with the Marzocchi Sport/LeMans forks.
Bob Maynard Posted March 21, 2021 Posted March 21, 2021 In search of more comfort for a broken/repaired pelvis and hip socket, I gave in to drilling my top triple today. I left the brackets for the Verlicchi touring bars in place so I can return it to that configuration super easily, if the ape hangers I’m installing don’t work out. Easy to put ss snap in buttons to cover the holes. I’m using a set of VStrom short risers from eBay. I’ve got a set of hose extensions from helibar if needed. Again, easily returnable to stock, and can get custom hoses if my pelvis says yes. 2
fotoguzzi Posted March 21, 2021 Author Posted March 21, 2021 Of course your right Docc, I don't know what I was thinking.. back to the original question. Will a Centauro top triple fit a V11.. I have the Centauro part but no V11 to camp are to. 1
Lucky Phil Posted March 21, 2021 Posted March 21, 2021 On 3/21/2021 at 10:00 PM, fotoguzzi said: Of course your right Docc, I don't know what I was thinking.. back to the original question. Will a Centauro top triple fit a V11.. I have the Centauro part but no V11 to camp are to. Expand If you can measure the fork dia and offset I can measure the V11 and give you an idea. I'm sure the stem will be the same as I'm sure the top clamp nut is common to them both. Ciao 1
fotoguzzi Posted March 21, 2021 Author Posted March 21, 2021 On 3/21/2021 at 10:21 PM, Lucky Phil said: If you can measure the fork dia and offset I can measure the V11 and give you an idea. I'm sure the stem will be the same as I'm sure the top clamp nut is common to them both. Ciao Expand 58mm and approximately 108mm
Lucky Phil Posted March 21, 2021 Posted March 21, 2021 On 3/21/2021 at 10:49 PM, fotoguzzi said: 58mm and approximately 108mm Expand V11 Sport Greenie. Between the fork centres....210mm Fork upper dia 54mm Offset ( distance from the ctr of the steering stem and a line through the Fork centrelines) .....36mm I "think" later tripple clamps were a fraction different due to the longer frame. Ciao
fotoguzzi Posted March 21, 2021 Author Posted March 21, 2021 On 3/21/2021 at 11:16 PM, Lucky Phil said: Offset ( distance from the ctr of the steering stem and a line through the Fork centrelines) .....36mm I Expand Wouldn't that be more like 105mm ? anyway it's 54vs 58 so not the same.
docc Posted March 21, 2021 Posted March 21, 2021 Offset is how far forward the forks are from the steering stem. So, yeah, like an inch and a half, but not four inches . . .
