57 minutes ago, Chuck said:
Well, that's a relief. I didn't realize it came from a forum guy.. no offense intended.
Appreciate that Chuck..
This really is a good reminder to inspect that 30 amp fuse regularly. They are known to melt, char, or even burn off a blade without "blowing" the fuse itself. The consensus has been the fuse connections are an electrical "choke point" for the charge amperage and prone to excessive heat. I struggled with this for so long before I converted to an aircraft grade circuit breaker. This makes it a *snap* to disconnect for charging sessions.
I am also operating under the theory that keeping the PC545 "conditioned," and the regulator grounded to the engine, gives the V11 charging system less need to push 20-25 amps back to the battery. Expecting our V11 charging system to bring a hefty PC545 back up from 12.5 volts (50%!) may be expecting too much; and adds up to a formula for charging system failures, IMO.
17 hours ago, docc said:
Simple enough, then! Back in with fuse and do the voltage check that Lucky Phil posted at about 2500 rpm looking for 13.8-14.2 volts.
FWIW, I always disconnect my regulator from the battery when charging. As I recall, EME (where I get my regulators) emphasizes this procedure.
Success! Got the correct voltage check at rpm's. Took her for a nice 20 minute ride yesterday afternoon and all looks good so far. Battery reading 12.9 this morning about 12 hours sitting.
i have been reading your older thread on this Doc, thank you good stuff. Just a question. Are you saying we would be better off with a standard battery instead of the Odyssey to avoid the 'meltdown'?
No, I'm a dedicated PC545 devotee. My theory, that I practice, is 1) since the PC545 takes significant amperage to charge, and 2) the V11 has some weaknesses in its charging system (regulator diodes, vulnerable 30 amp fuse, stator wires), I propose it is Best Practice to keep the Odyssey PC545 fully and correctly conditioned with approved external chargers/method to minimize strain on the charging system. I would not leave on my Sport with the battery under 12.65 volts without conditioning it.
Some find it too much of a hassle, but I prefer to avoid the otherwise inevitable major hassle of the roadside variety. :o
Or, you can do a small job with another regulator, feeding 14.73 V idling, directly to the battery. Then you can forget about the 30amp fuse.
Cheers Tom 08c05df818c6ad734a87d3eec0809a1a.jpg257ede961835947cd4feb1bfe8894ff7.jpg
Sent fra min SM-A505FN via Tapatalk
14.73 would be to high for an PC545 I think. Whats the charge rate with the revs up?
1 hour ago, Chuck said:
The "redline" for an Odyssey is 15V.
This is true, yet they publish the charging range as 14.2-14.7.  Once the battery reaches a 100% state of charge, the voltage can be tapered to 13.5-13.8. While correct external chargers will do that, our V11 regulators are fixed voltage (should be 14.2, IIRC).
Phil, it Don’t exceed 14.8V.
Cheers tom.
First time Odyssey here, says 0121 on it, jan 21. 12.96 V delivered. Dropped voltage a bit, and charged with 7amp CTEK. 5days 13.03V - 13.00V. Will check that my charging system can keep up with the Odyssey. $ 272,so.
Different batteries shown. While the Odyssey will probably tolerate a constant 14.7 charge, that EXIDE? I would be watching for signs of overpressure, vapor hazing. Acidic battery puke is an ugly thing :vomit:
Ugly is bad. AGM Exide can handle 14.8 V, prooved 2 seasons,  but it drops the V when battery is full, of course  :rasta:
Cheers tom.
