swooshdave Posted May 16, 2021 Posted May 16, 2021 Not the orange drink, the wire thing that sticks out and breaks. Or at least mine did. So I whipped up a prototype. It's probably too thin but I'll see how long it lasts. 2
swooshdave Posted May 16, 2021 Author Posted May 16, 2021 It looks like the correct description is: https://www.mgcycle.com/index.php?main_page=product_info&cPath=73&products_id=5546 SIDE STAND DEPLOYMENT LOOP Almost $30. Am I correct these break a lot? It wouldn't be hard to design something way better. 3D print up some dies and press a few.
Scud Posted May 16, 2021 Posted May 16, 2021 I haven't had one break, but I've heard of plenty breaking, so I am super-careful with mine and have managed to stash at least one spare away in my box of goodies. When Chuck and I were deep into shift spring engineering and production, we learned that the spring material was bent too tightly for its diameter, which created weak points at the bends - and explained the failures. I suspect these "side stand deployment loops" suffer from the same issue. I think you could have a set bent up by a spring maker with correct radii on the bends. The spring maker I used was willing to make the side stand parts if I would give them specs - but I never pursued it. Count me in as a buyer if somebody decides to do this. I don't think I would buy a pressed metal plate. I am not a big fan of having a sheet metal blade by my left Achilles tendon. Even though I almost always wear good boots. I'd rather have something that would bend or break. 1
docc Posted May 16, 2021 Posted May 16, 2021 I've had at least a couple break. Perfect application to repurpose the safety retention washer that failed on my gearbox input hub . . . 2
Lucky Phil Posted May 16, 2021 Posted May 16, 2021 On 5/16/2021 at 6:38 PM, swooshdave said: It looks like the correct description is: https://www.mgcycle.com/index.php?main_page=product_info&cPath=73&products_id=5546 SIDE STAND DEPLOYMENT LOOP Almost $30. Am I correct these break a lot? It wouldn't be hard to design something way better. 3D print up some dies and press a few. Expand This guy is impressive. Ciao
stewgnu Posted May 17, 2021 Posted May 17, 2021 Mine broke too. I used a stainless 60mm cap-head screw for a couple years 🙂
swooshdave Posted May 18, 2021 Author Posted May 18, 2021 On 5/16/2021 at 7:39 PM, Scud said: I don't think I would buy a pressed metal plate. I am not a big fan of having a sheet metal blade by my left Achilles tendon. Even though I almost always wear good boots. I'd rather have something that would bend or break. Expand How is this near your achilles? Do you have highway pegs on your V11?
Scud Posted May 18, 2021 Posted May 18, 2021 That's funny. And you're correct that the part is in front of the pegs, not behind. My bad. However, I'd still be a little concerned about the sheet metal.
swooshdave Posted May 18, 2021 Author Posted May 18, 2021 On 5/18/2021 at 8:55 PM, Scud said: That's funny. And you're correct that the part is in front of the pegs, not behind. My bad. However, I'd still be a little concerned about the sheet metal. Expand You should be way more concerned about that cast metal side stand. Neither the sheet metal or bent wire will do much to you.
Chuck Posted May 18, 2021 Posted May 18, 2021 Just buy one from Cheesehead and Gordon at MGC and be done with it.. And from the video.. 3D printed sheet metal dies.. will it survive? No. No it won't. Trust me, I apprenticed as a sheet metal diemaker.
Rox Lemans Posted May 19, 2021 Posted May 19, 2021 Looks meh. But better than stock. I'd buy one. 😉
swooshdave Posted May 19, 2021 Author Posted May 19, 2021 On 5/19/2021 at 4:42 AM, Rox Lemans said: Looks meh. But better than stock. I'd buy one. 😉 Expand This was just my first draft and no it doesn't look great. It's flimsy but it works. I'd like to see what else people have done. 1
swooshdave Posted May 19, 2021 Author Posted May 19, 2021 On 5/18/2021 at 9:51 PM, Chuck said: Just buy one from Cheesehead and Gordon at MGC and be done with it.. And from the video.. 3D printed sheet metal dies.. will it survive? No. No it won't. Trust me, I apprenticed as a sheet metal diemaker. Expand Did you actually watch the video? Remember a die only needs to survive as long as your production is. If you are making dozen units do you want to over-invest in dies? If you are making 10k then no, they will not last. While I could just get the stock one I think we've proven that the stock part isn't always the best.
swooshdave Posted May 19, 2021 Author Posted May 19, 2021 This is an interesting option. It looks horrible. I wonder how long those welds will hold up. https://www.stein-dinse.biz/product_info.php?language=sc&products_id=4940
