Jetdoc Posted July 17, 2021 Posted July 17, 2021 Is the Roper Plate for the V11 a direct fit to the Centauro or are there different models of the plate? Can Pete or someone out there please set me straight? Thanks, Jetdoc
Chuck Posted July 17, 2021 Posted July 17, 2021 For whatever reason, a Roper plate doesn't seem to be needed on the Centauro. That said, as far as I know.. they're the same. 1
Weegie Posted July 17, 2021 Posted July 17, 2021 2 hours ago, Chuck said: For whatever reason, a Roper plate doesn't seem to be needed on the Centauro. That said, as far as I know.. they're the same. Why not Chuck? As I understand it, Pete originally designed them for the V11s as they were lunching cranks at an alarming rate. The Centauro/Daytona/Sportis less so but only by nature of less aggresive gear ratios meaning they were less prone to the pickup getting uncovered under hard acceleration Pete recommended I install one on my Sporti and as the Centauro/Daytonas are similar I put one on that engine too. Over on the COG forum there were quite a few threads on "Sloppage Sheets" and a lot of people installed them I'd strongly recommend them for any broadsump engine. The plate also has the added benefit of allowing more oil to be stored in the sump which also helps
Pressureangle Posted July 17, 2021 Posted July 17, 2021 I've installed one in my Sport-i of course, even though it's acknowledged that 5-speeds don't have the low gear acceleration enough to create a problem. I never saw my oil lamp flicker; but hey, it's a known issue with this engine configuration, and they're cheap insurance. What if one lives on a steep grade? Besides, all the cool kids have them. 1
Kostarika Posted July 17, 2021 Posted July 17, 2021 The plates are not the same. I can take a picture in a few days if you’d like. 1 1 1
Jetdoc Posted July 18, 2021 Author Posted July 18, 2021 Kostarika: Based on your response and your listed bikes, am assuming you have plates for both your V11 and Centauro? Did you get both of these plates from Pete or another source? Was betting on them being the same, shows what I know.
footgoose Posted July 18, 2021 Posted July 18, 2021 48 minutes ago, Jetdoc said: Kostarika: Based on your response and your listed bikes, am assuming you have plates for both your V11 and Centauro? Did you get both of these plates from Pete or another source? Was betting on them being the same, shows what I know. AFAIK the one and only plate fits V11, 1100 Sport, Daytona and Centauro 1
pete roper Posted July 18, 2021 Posted July 18, 2021 I only designed the one plate for 'Broad Sump' engines and it fits all models. If the plagiarists who stole the design have changed it slightly it would be unnecessary. I believe, from memory, that the later plates have a slightly longer dipstick slot to prevent the stick fouling on the plate but apart from that my design never changed when I was manufacturing them. 2 3
fotoguzzi Posted July 18, 2021 Posted July 18, 2021 I'd sure like to know the names of the plagiarists, care to share?
Pressureangle Posted July 18, 2021 Posted July 18, 2021 18 minutes ago, fotoguzzi said: I'd sure like to know the names of the plagiarists, care to share? The signpost is a rusty Star Picket. 1
Jetdoc Posted July 18, 2021 Author Posted July 18, 2021 Thanks Pete for clearing the air on the question!
Scud Posted July 18, 2021 Posted July 18, 2021 Hey Pete - I imported a bunch of plates from you for a group buy for members of this site several years ago. There were 2 different plates. I think the other was for Tonti-framed bikes. Out of curiosity, and since I now have a 1989 Lemans 1000, which bikes are your Tonti plates intended for?
