KenBlake Posted August 31, 2021 Posted August 31, 2021 Hello, I would like to replace the headers on my 2004 Ballabio with a set that does not have the crossover. I am wondering if these would work: https://www.ebay.com/itm/324588014078 I have a Stucchi x pipe that this would need to feed into. Thank you!!
Lucky Phil Posted August 31, 2021 Posted August 31, 2021 2 hours ago, KenBlake said: Hello, I would like to replace the headers on my 2004 Ballabio with a set that does not have the crossover. I am wondering if these would work: https://www.ebay.com/itm/324588014078 I have a Stucchi x pipe that this would need to feed into. Thank you!! Nope totally different shape. There are some non cross over V11 sport headers on ebay you know. Items 384351533431 and 164043373894 Ciao 1
red lion Posted August 31, 2021 Posted August 31, 2021 Will the headers from a centauro fit on a V11?
Admin Jaap Posted August 31, 2021 Posted August 31, 2021 20 minutes ago, red lion said: Will the headers from a centauro fit on a V11? I did it the other way around and as far as I can remember that worked.
Lucky Phil Posted September 1, 2021 Posted September 1, 2021 3 hours ago, Admin Jaap said: I did it the other way around and as far as I can remember that worked. Same, the std headers from my V11 fitted perfectly to the Centy engine in a v11 frame with the v11 Stucchi cross over, amazingly. Ciao 1
