VtwinStorm Posted September 9, 2021 Posted September 9, 2021 Longitudinal engine (N-S) orientation in the chassis. Separate gearbox, no sharing fluid with the engine. Driveshaft, like most cars. Also with a rear differential, like a car. Can anyone else point out other engineering that is more automotive than motorcycle on a Guzzi V Twin? These bikes really are interesting.
VtwinStorm Posted September 9, 2021 Author Posted September 9, 2021 47 minutes ago, MartyNZ said: A dry clutch, like a car Yes, forgot that one. Not submerged in oil like most motorcycles...
pete roper Posted September 9, 2021 Posted September 9, 2021 Your Guzzi has a Differential? Why? Is it a trike?
VtwinStorm Posted September 9, 2021 Author Posted September 9, 2021 4 minutes ago, pete roper said: Your Guzzi has a Differential? Why? Is it a trike? Sorry, wrong term...bevel box.
VtwinStorm Posted September 9, 2021 Author Posted September 9, 2021 1 minute ago, pete roper said: Better. Also known as a final drive. I'm learning Guzzis... I'm more experienced with air-cooled Ducatis. Still learning...
GuzziMoto Posted September 9, 2021 Posted September 9, 2021 Single cam in the V, with push rods to the valves is more common on cars than motorcycles. But really I would not call any of this "automotive engineering". Old school engineering perhaps. Once upon a time many motorcycles used similar engineering. 1 1
80CX100 Posted September 10, 2021 Posted September 10, 2021 It's been discussed many times in the past, so I'm surprised no one has mentioned it here. The guzzi engine is basically the last 2 cylinders of the old Chevy 350 V8, ie. 90 degrees, low compression, 2 small valves, pushrods, rocker arms, going back to a dry clutch, tranny and drive shaft. fwiw 1 1
Scud Posted September 10, 2021 Posted September 10, 2021 Well, I think there is a better case that the old BMW flying brick engines were car technology stuffed in a motorcycle. Except they made the flywheel and clutch spin opposite of the engine, which is pretty cool. That made it motorcycle only. 1
po18guy Posted September 10, 2021 Posted September 10, 2021 29 minutes ago, 80CX100 said: It's been discussed many times in the past, so I'm surprised no one has mentioned it here. The guzzi engine is basically the last 2 cylinders of the old Chevy 350 V8, ie. 90 degrees, low compression, 2 small valves, pushrods, rocker arms, going back to a dry clutch, tranny and drive shaft. fwiw But, it's got a HEMI!!! Guzzi v. Chrysler 426. 1
VtwinStorm Posted September 10, 2021 Author Posted September 10, 2021 21 minutes ago, po18guy said: But, it's got a HEMI!!! Guzzi v. Chrysler 426. This also! Hemispherical heads.
Lucky Phil Posted September 10, 2021 Posted September 10, 2021 41 minutes ago, 80CX100 said: It's been discussed many times in the past, so I'm surprised no one has mentioned it here. The guzzi engine is basically the last 2 cylinders of the old Chevy 350 V8, ie. 90 degrees, low compression, 2 small valves, pushrods, rocker arms, going back to a dry clutch, tranny and drive shaft. fwiw That's a stretch. A 350 Chev is water cooled, bathtub or wedge shaped combustion chamber, paired valves with inlet between the V and exhaust the other side so transverse cross flow. Ones all aluminium and ones Iron/iron or Iron/aluminium. I guess they're both 90deg 4 stroke piston engines Ciao 1
docc Posted September 10, 2021 Posted September 10, 2021 So, even with as many commonalities we can name between the Moto Guzzi "Big Block" and the beloved American V8, the Guzzi motor is a thing of its own, purposefully designed, and elegantly executed. " . . . with the presence of a Norman horse . . . " 2
