My odometer stopped working on the 1100 sport. How hard is it to remove the speedo?
It is a white face Veglia, like the early V11 Sport?
Seems that Joel LeVine in Georgia, USA, can service these fragile instruments?
Check if the Speedo cable is actually turning at the Speedo end first! Disconnect it from the back of the Speedo.
If you spin and push it into the cable housing you should feel it "lock" ok into the gearbox end. If it's just flapping about it could be broken.
If you've got a stand just start the bike and put it in gear. See if the cable spins at the Speedo end.
If it's the black ITI one, you can service them.... Just about. With replacement worm gears.
If you talking about unsealing the bezel from the gauge, it is not very difficult. You need to pry it out with a very thin blade. Don't use the only screwdriver you could find. Use something thin with a large blade to minimize the damage you could cause to the plastic rim of the bezel.
When sealing it back, use some very light glue, so you may be able to open it again if you need to.
The trip meter and speedo are still working so the cable should be OK. I would think the gears must be worn on the odometer. It looks like the front fairing needs to come off to remove the speedometer.
