Does anyone have a source? Other than MG Cycle, I can't seem to find them anywhere. No one seems to have the caps. Gotta get the red set...too sexy.
Thank you all!
Just Google NGK spark plug wires. I use them on my bike.
Sent fra min SM-A525F via Tapatalk
The early Sport used Champion resistor caps. Later V11 were NGK.
I have gotten the red Champions from a scooter supplier in the UK (Champion is UK, as in Albert Champion or "AC", as in AC/Delco) . . .
Let me find contact info . . .
I'm not finding that source in the UK, but web search "Champion PRO5U" and you'll have multiple sources . . .
Docc, you are the Yoda of this amazing forum. Thank you!
Funky with you, your Sport will be.
  • Haha 3
"I am not afraid of greasing the front U-joint on my RedFrame Sport, Master Yoda."
  • Haha 2
Guessing some disassembly is required for that, yes?
"I'm not afraid . . ." :huh:
(Mess with you, Yoda does.)
  • Haha 4
Hmmm... while I'm greasing the u joints, might as well replace the entire clutch assembly. Just a simple 8 hour (?) job...
Anyone have the OEM or Champion part number for the OEM red spark plug wires? I already found the caps and ordered them.
Grazie!
Epic thread drift. I promise to report myself to myself. :whistle:
No, really, the front UNI is >approachable< on an early RedFrame. It is. It is.
  • Haha 4
Grazie!
Yes, what are the OEM early RedFrame red spark plug wires? I don't think these are Champion. I am also looking to replace mine. They are quite long, actually . . .
They appear to measure 7mm (7.5mm?) outside diameter.
 What is wrong with this 7.5 mm solution at $1.99US/foot?
https://www.oreillyauto.com/detail/c/standard-ignition/performance/ignition/spark-plug-wire---bulk/283f648a25cc/standard-ignition-7-5mm-100-foot-primary-ignition-wire/std0/cc75c?pos=4
[edit: okay, shipped to me (in the USA) with taxes, five feet of this wire is $22.68US. Four feet is probably enough, but I hate to come up short. Coil end connectors must be added, but these should "screw" into the spark plug 90º angle connectors.]
Grazie!
From the Parts Catalog, here is the Moto Guzzi part number for the early Sport, red, "HT wire":  GU01718330
