Chuck Posted October 18, 2021 Posted October 18, 2021 3 hours ago, gstallons said: I though green was the "easiest" Loctite ? Nope.. I have some experience with Loctite.. 1 1
Twin AH Posted October 18, 2021 Author Posted October 18, 2021 OK.............. so no one has a decent 5.5 wheel for consideration?? 1
Mike Stewart Posted October 18, 2021 Posted October 18, 2021 On 10/16/2021 at 10:40 PM, Twin AH said: Yup I saw that one on ebay as well as the Coppa/Cafe Sport wheel that unfortunately they broke off a few studs that hold the brake rotor. What a shame. It's easy to remove the broken bolts to the rotors if you have a mig welder, just place a 8mm washer or nut over the broken bolt and weld a bead to fill the hole (try not to over heat it). The heat usually is enough to release the locktite and can be removed easily unless it was cross threaded. I have done a few over the years this way. 1 1
Twin AH Posted October 18, 2021 Author Posted October 18, 2021 5 hours ago, Mike Stewart said: It's easy to remove the broken bolts to the rotors if you have a mig welder, just place a 8mm washer or nut over the broken bolt and weld a bead to fill the hole (try not to over heat it). The heat usually is enough to release the locktite and can be removed easily unless it was cross threaded. I have done a few over the years this way. I have done a few over the years as well............ The big trick on these is saving the very hard to duplicate finish on the wheel. Ciao 1
Twin AH Posted November 20, 2021 Author Posted November 20, 2021 Thx all.............. mission accomplished. Ciao 1
