docc Posted October 26, 2021 Posted October 26, 2021 6 hours ago, Lucky Phil said: Actually Pete there is one semi significant difference. Some have an 8mm side stand bracket threaded mount bolt hole and some have a 6mm bolt which can be a bit of a pain if you have the wrong one as I did when I did the V10 Sport. Didn't realise until I went to refit the side stand bracket. It's not straight forward opening up the 6mm side stand bracket hole to accommodate the 8mm cap screw head. Not without a mill anyway. Ciao Is that this location, @Lucky Phil?
Lucky Phil Posted October 26, 2021 Posted October 26, 2021 7 hours ago, docc said: Is that this location, @Lucky Phil? Thats it docc. Opening the hole is no problem but grinding away the steel bracket to give clearance for the larger cap screw head is a pain unless you have a mill and then it would be straight forward. It's not obvious in the image. Ciao
