4corsa Posted October 23, 2021 Posted October 23, 2021 ...on my 03 Le Mans, rear of transmission. Any idea what this is for? Assuming I should pump some grease into it - no? Sent from my Pixel 4a using Tapatalk
4corsa Posted October 23, 2021 Author Posted October 23, 2021 Doh! Thanks Footgoose!Sent from my Pixel 4a using Tapatalk
po18guy Posted October 23, 2021 Posted October 23, 2021 4 hours ago, 4corsa said: ...on my 03 Le Mans, rear of transmission. Any idea what this is for? Assuming I should pump some grease into it - no? Sent from my Pixel 4a using Tapatalk Rather than LeMans, the bikes could have been named the LeMarquis de Sade. Rear wheel off, you can almost reach it without pain. Wiggling the petrified cap off and actually connecting a bleeder hose - then undoing and replacing the whole mess - was my exercise for the month. But, the clutch has worked faultlessly ever since.
billgreenman1 Posted October 24, 2021 Posted October 24, 2021 ...and I was hoping that this post was going to be about a newly discovered anatomical oddity la-la Scaramanga...how's that for obscure references? 1
Lucky Phil Posted October 24, 2021 Posted October 24, 2021 4 hours ago, po18guy said: Rather than LeMans, the bikes could have been named the LeMarquis de Sade. Rear wheel off, you can almost reach it without pain. Wiggling the petrified cap off and actually connecting a bleeder hose - then undoing and replacing the whole mess - was my exercise for the month. But, the clutch has worked faultlessly ever since. Really? Ciao 1
po18guy Posted October 24, 2021 Posted October 24, 2021 5 minutes ago, Lucky Phil said: Really? Ciao As to access, yes. I cut easily. I bleed easily. I like neither, so off the wheel came.
Scud Posted October 24, 2021 Posted October 24, 2021 Next time I flush the clutch fluid I am going to try installing a hose for remote bleeding as my Stelvio (and I assume other CARC bikes). My Stelvio has a line where that bleeder valve goes. It terminates under the seat with a bleeder valve. 2
docc Posted October 24, 2021 Posted October 24, 2021 1 hour ago, Scud said: Next time I flush the clutch fluid I am going to try installing a hose for remote bleeding as my Stelvio (and I assume other CARC bikes). My Stelvio has a line where that bleeder valve goes. It terminates under the seat with a bleeder valve. I’d love to see how that turns out, @Scud! 1
pete roper Posted October 25, 2021 Posted October 25, 2021 It makes bleeding the clutch on CARC bikes a dream.
