Kane Posted March 9, 2022 Posted March 9, 2022 docc, when ever I see pictures of your bike’s engine I am always impressed by how clean it is! Not one trace of oil seepage, road grime……nothing! So, in addition to the Barry White to go along with your sexy bike lift lighting, here’s one for your oh-so-clean engine: 2 1
docc Posted March 10, 2022 Posted March 10, 2022 On 3/9/2022 at 1:39 PM, Kane said: docc, when ever I see pictures of your bike’s engine I am always impressed by how clean it is! Not one trace of oil seepage, road grime……nothing! So, in addition to the Barry White to go along with your sexy bike lift lighting, here’s one for your oh-so-clean engine: Soooo, turns out she loves the spotlight, the stage, the footlights. (Me? I'm just a backstagehand.) I produced that photograph for a college art class. If I knew then what I know now, I would have titled it "Love is a Burden" . . . 2
cash1000 Posted May 10, 2022 Posted May 10, 2022 Or you could make your own factory stand or MartyNZ has an even better one that he might like to show here 2
cash1000 Posted May 10, 2022 Posted May 10, 2022 Just now, cash1000 said: Or you could make your own factory stand or MartyNZ has an even better one that he might like to show here Another Photo 1 1
Lucky Phil Posted May 10, 2022 Posted May 10, 2022 3 hours ago, cash1000 said: Another Photo Yes I got an almost identical one when I bought my bike, Damaged paint to the pork chops and dangerous as hell to use, with the bike moving backwards about 6 inches as it rolls onto the stand. You were also unsighted to one of the nut supports when using it and hoped it hadn't moved out of position as you moved the bike upright and got it settled. It was so dodgy I stopped using it. Anyone that wants it can have it for nothing. The beauty of the socket type with wheels is the stand stays captive on the mount nuts so the stand can't disconnect from the bike and the stand rotates safely and controllable under the bike on its own wheels. It also means you can roll the bike into a front wheel chock so it's vertical and lift the rear of the bike while in the chock. For the sake of $150 or so the other type isn't worth the risk. Ciao 1
MartyNZ Posted May 10, 2022 Posted May 10, 2022 5 hours ago, cash1000 said: Or you could make your own factory stand or MartyNZ has an even better one that he might like to show here I looked at Cash1000's stand, and thought I could make one like it, but red, and with wheels. It has plastic clevises to avoid marking the pork-chops. 4
docc Posted May 19, 2022 Posted May 19, 2022 Since I routinely use the Baxley SportChock to index the front tire on the lift, it gives me great trepidation (the "heebie-jeebies" ) when I have to remove the front wheel for a tire change/ brake service/ fork service. Belts and suspenders (and lift and platform jack) using the rear tire as an index point this time . . . 1
Chuck Posted May 19, 2022 Posted May 19, 2022 Front tire change is easy. Just back it into the chock, tie it down, and lift under the motor.. 1
docc Posted May 20, 2022 Posted May 20, 2022 14 hours ago, Chuck said: Front tire change is easy. Just back it into the chock, tie it down, and lift under the motor.. I would need a couple other capable guys to back mySport up onto the lift into the chock. Solo? No way. Y'all come, now! Ya hear? 1
Speedfrog Posted May 20, 2022 Posted May 20, 2022 14 hours ago, Chuck said: Front tire change is easy. Just back it into the chock, tie it down, and lift under the motor.. 8 minutes ago, docc said: I would need a couple other capable guys to back mySport up onto the lift into the chock. Solo? No way. I hear you Docc, what sounds like a good idea seems a little risky with a 500lbs bike... I would not try that solo. 1
80CX100 Posted May 20, 2022 Posted May 20, 2022 Putting the bike on a lift and using a jack to raise it to get the front wheel off is relatively easy. Getting it up in the air, supported, balanced and tied off securely so you can remove both wheels at the same time; requires some careful thought and planning. My Tonti frames with a center stand are child's play in comparison. fwiw ymmv jmho 1
Randy Posted May 20, 2022 Posted May 20, 2022 On 3/9/2022 at 10:15 PM, docc said: Soooo, turns out she loves the spotlight, the stage, the footlights. (Me? I'm just a backstagehand.) I produced that photograph for a college art class. If I knew then what I know now, I would have titled it "Love is a Burden" . . . Hey, you found bag racks for it. Where'd they come from?
docc Posted May 20, 2022 Posted May 20, 2022 6 hours ago, Randy said: Hey, you found bag racks for it. Where'd they come from? I replaced one of my originals with part of a set another member had for sale here. The fitment was very subtly different even though they were both first gen Tekno.
Goofman Posted August 20, 2022 Posted August 20, 2022 How many Goofmen does it take to right a V11? 1
Pressureangle Posted August 21, 2022 Posted August 21, 2022 For front wheel service, I put a Pit Bull stand under the swingarm and a small jack with wood block under the front of the sump.
