Thank you for info. I see that this one and another one on eBay both are used.
I am hoping to find someone that can sell me a new one.
I will be waiting for more people to reply.
You have checked with Stein-Dinse, Teo Lamers, HMB Guzzi?
I bought the used one you refered to.
It seem that 2975915 Cal 2/3/1100) and 375910 (Centauro) has the same switch part - but another cable connection. Maybe I can buy one of them and change connector?
Thanks for info anyway. Maybe someone else will be happy about this latest info.
Rolf
Expand
Gutsibits have new ones.
Thank you for this reply. Gutsibits writes that they hav 5 used one available (but no shipping to US or Canada).
I bought one used one as said before - and found a brand new one in Norway - 375910 (Centauro) .
When I get them  both - I can see if the sensor are identical and that only the cable connection are different.
Rolf
Posted (edited)
Expand
The sidestand pickup for V11 Sport is 01759130. I can now verify that the pickup-sensor and the wire lenght are identical on all these side stand pickups (mentioned  above) Only the cable connector are different. This makes it easier to get a new pickup and only change the connector.
When the sidestand is active - the wires are not in contact witheach other. When the sidestand is in a drivable position - the wires have connection with each other.
This means that if you have a defect pickup, you can take away the cable and put both wires in contact with each other. Then you can drive as normal.
Edited by Rolf Halvorsen
writing error
  • Like 4
