cash1000 Posted November 15, 2021 Author Posted November 15, 2021 It's the 2 closest to the battery. If you Google the numbers & letters on top line in side of relay you will find listings for them with specifications. I won't pretend to understand them 😊
MartyNZ Posted November 15, 2021 Posted November 15, 2021 I couldn't read the marks on your picture, so I looked at the original pic. It says FRC7C-SR-1, 12VDC, NO 30A, NC 25A, at 14VDC Spec sheet attached. I do like the idea of the wider 4.8mm pins rather than the thin 2.8mm pins 85 & 86 on some Omron relay types. FRC7 Relay.pdfFetching info... 1 1
cash1000 Posted November 15, 2021 Author Posted November 15, 2021 I see what you mean. Image lost definition once I uploaded it. What's he mean by remove pins and crimp terminals ( see invoice)?
MartyNZ Posted November 15, 2021 Posted November 15, 2021 On 11/15/2021 at 8:52 AM, cash1000 said: What's he mean by remove pins and crimp terminals ( see invoice)? Expand I think he removed some spade sockets, and crimped on new ones. 1
docc Posted November 15, 2021 Posted November 15, 2021 On 11/15/2021 at 6:01 PM, MartyNZ said: I think he removed some spade sockets, and crimped on new ones. Expand Hmm, I was thinking it meant he removed the terminals in the relay bases and tightened ("Crimped") them . . . 1
MartyNZ Posted November 16, 2021 Posted November 16, 2021 On 11/15/2021 at 6:07 PM, docc said: Hmm, I was thinking it meant he removed the terminals in the relay bases and tightened ("Crimped") them . . . Expand You're probably right. That would be Kiwi_Roy's "Relay Base Repair" See attachment. Cash1000 and I already did that repair some years ago. Maybe next time we should renew the terminals instead of just crimping. Relay Base Repair.pdfFetching info... 2 1
gstallons Posted November 21, 2021 Posted November 21, 2021 As usual , perfect advice and instructions . 1
