Mistral Crossover 99-02 V11 Sport & Le Mans w/ NO lambda port. Used but in very good condition. $350 new at MG Cycle, yours for half that: $175 plus shipping (from New Jersey, USA).a72b135dcfbcedc88c2977eb2fe4fe88.jpg0fe08a01999c2564b67806c62e52c2bc.jpg
Sent from my Pixel 4a using Tapatalk
20 minutes ago, footgoose said:
Wow, the best for cheap!
Well the second best for cheap. Good deal though esp considering you can't buy the Stucchi anymore.
"Best" is perhaps down to a difference in where you want your power . . .
I'm more interested in what the dyno says docc and the dyno says the Stucchi loses nothing in the midrange to the Mistral and has a whole lot more on the top end (6-8 HP, gulp). As a matter of fact the Mistral has less top end than the std cross over. Both are better in the midrange than the std crossover. I don't mind sacrificing a HP or 2 at the top end for more mid range grunt but 6-8 is a bit much for me.
You need to cross reference between the 4th last and 2nd last graphs. Check the HP dif at 3500 rpm. 4 more to the Stucchi. It's just the torque dip is shorter and sharper with the Mistral it doesn't make better numbers in the midrange and for this you sacrifice 6 or 7 HP on the top end. Nah.
https://www.bikeboy.org/v11sport.html
  • Like 3
Hi 4corsa   I Sent you a PM. Did you received it?
Replied to both - perhaps there's a delay?
It's sold
