4corsa Posted November 20, 2021 Posted November 20, 2021 Mistral Crossover 99-02 V11 Sport & Le Mans w/ NO lambda port. Used but in very good condition. $350 new at MG Cycle, yours for half that: $175 plus shipping (from New Jersey, USA). Sent from my Pixel 4a using Tapatalk 1
Lucky Phil Posted November 20, 2021 Posted November 20, 2021 20 minutes ago, footgoose said: Wow, the best for cheap! Well the second best for cheap. Good deal though esp considering you can't buy the Stucchi anymore. Ciao 2
docc Posted November 20, 2021 Posted November 20, 2021 "Best" is perhaps down to a difference in where you want your power . . .
Lucky Phil Posted November 20, 2021 Posted November 20, 2021 53 minutes ago, docc said: "Best" is perhaps down to a difference in where you want your power . . . I'm more interested in what the dyno says docc and the dyno says the Stucchi loses nothing in the midrange to the Mistral and has a whole lot more on the top end (6-8 HP, gulp). As a matter of fact the Mistral has less top end than the std cross over. Both are better in the midrange than the std crossover. I don't mind sacrificing a HP or 2 at the top end for more mid range grunt but 6-8 is a bit much for me. You need to cross reference between the 4th last and 2nd last graphs. Check the HP dif at 3500 rpm. 4 more to the Stucchi. It's just the torque dip is shorter and sharper with the Mistral it doesn't make better numbers in the midrange and for this you sacrifice 6 or 7 HP on the top end. Nah. https://www.bikeboy.org/v11sport.html Ciao 3
red lion Posted November 21, 2021 Posted November 21, 2021 Hi 4corsa I Sent you a PM. Did you received it?
Twin AH Posted November 21, 2021 Posted November 21, 2021 Me too......... looking forward to your reply. Ciao
4corsa Posted November 21, 2021 Author Posted November 21, 2021 Replied to both - perhaps there's a delay?Sent from my Pixel 4a using Tapatalk
4corsa Posted November 21, 2021 Author Posted November 21, 2021 It's soldSent from my Pixel 4a using Tapatalk 1
