Guest callithrix Posted March 26, 2004 Posted March 26, 2004 Hey Al I think you posted earlier that you installed the Kisan tailight, running light adapter. I purchased it this week and would like to know where are the tail light wires that I need to splice into so that I can get the running light option. Thanks in advance. Electrics always worry me.
al_roethlisberger Posted March 26, 2004 Posted March 26, 2004 Hrmm, that's a good question.... it's been almost 2 years since I installed mine All you have to do is find the 12V running light lead to the tail-light behind the bulb socket, and splice into it. They make an easy "vampire clamp" sort of splice that you can get at any auto parts store that just clips over the existing wire, and you plug a spade connector into it. It's clean and simple. You can then hook this to the power lead for the Kisan flasher. You can also do the same with the brake 12V lead to the tail-light for the turn-signal cancel delay. Hope that helps! al
