Does anyone know why when riding in the wet, rainwater can enter the gearbox.
How can this be prevented.
Cheers.
Hiya,
Yep, this is a common problem. The source is the transmission breather on the rear of the case, that is exposed to directed water spray from the rear tire.
One solution is to build a small triangular plastic fender insert, and mount it in the front trellis of the swingarm, as illustrated at:
Forum Inner Fender Modification Thread
Other solutions suggested before include changing out the breather to another type, or modifying the cap on the breather to accept a remote hose.
So far though, I think the fender modification has worked well enough for most folks.
Hope that helps ^_^
al
Guest northend
I am personally going to come up with a nice hose extension for the breather due to the fact that the gear lube has a tendincy to dribble out under hard acceloration or during wheelies :bike: I think I also need a Dictionary :homer:
Hope this helps.......Jeff H.
