docc Posted June 10, 2022 Posted June 10, 2022 On 6/10/2022 at 1:12 PM, velofish said: Anything else I should look at while the tire is off? Thanks again. Expand 1
po18guy Posted June 11, 2022 Posted June 11, 2022 No special bleeder needed - except a bleeder banjo bolt at the master cylinder. This easily cured the air problem my V11 developed. The M/C being the high point in the system, the air naturally rises to it. And, need I say...it is "slightly" more accessible than deep in the bowels of the machine. This Ti unit is from RaceTi in the UK. Not all that expensive and very well made.
Scud Posted June 11, 2022 Posted June 11, 2022 I've not seen a bleeder on a master cylinder connection before. Could be convenient, I guess. If I am concerned about air being trapped in a high point of the system there, I just unmount the master and tilt it so the bottom of the reservoir is higher. Air can return to the reservoir that way and get out of the line. 1
80CX100 Posted June 11, 2022 Posted June 11, 2022 On 6/10/2022 at 1:12 PM, velofish said: Anything else I should look at while the tire is off? Expand If the battery tray bracket hasn't been lowered, you may want to consider it. If it's due, bleeding the rear brake at the same time as the clutch. Cleaning up the main ground above the swing arm inboard of the driveshaft. I've probably forgotten something. I think if you search for it, Docc had compiled a list of maintenance items to do/check whenever the rear wheel is off. fwiw 2
docc Posted June 11, 2022 Posted June 11, 2022 On 6/11/2022 at 2:34 PM, 80CX100 said: If the battery tray bracket hasn't been lowered, you may want to consider it. If it's due, bleeding the rear brake at the same time as the clutch. Cleaning up the main ground above the swing arm inboard of the driveshaft. I've probably forgotten something. I think if you search for it, Docc had compiled a list of maintenance items to do/check whenever the rear wheel is off. fwiw Expand Yep, search about four posts back . . . I had not thought of adding the battery basket drop to the Wheels Off Maintenance Checklist ! [edit: Done! Thanks @80CX100 ! ] 1 1
velofish Posted June 20, 2022 Posted June 20, 2022 Thanks everybody!! Still working on the machine: experiencing “option overload” as too many chores, projects, and essential duties keep getting in the way. :) 1
