al_roethlisberger Posted March 17, 2023 Posted March 17, 2023 OEM part compatibility: "Valpollini" metal/wire core gasket options for the engine/sump gasket, valve/rocker cover gasket, and timing chain/gear cover. ENGINE SUMP GASKET CALIFORNIA 1400 SERIES, GRISO 1200 8V PART NUMBER: B063861 https://www.mgcycle.com/index.php?main_page=product_info&products_id=5495 VALVE COVER GASKET METAL BREVA 11/12 GRISO VINTAGE NORGE 976139 PART NUMBER: 976139B https://www.mgcycle.com/index.php?main_page=product_info&products_id=4634 METAL CORE TIMING COVER GASKET, BIG TWINS UNTIL 2009 GU05001230 PART NUMBER: 12001200M https://www.mgcycle.com/index.php?main_page=product_info&products_id=5044 Reference thread:
al_roethlisberger Posted March 17, 2023 Posted March 17, 2023 Wider OEM Mirrors For 2002+ Lemans These Buell mirrors are a bolt-on replacement for the MG OEM mirrors for the V11 Lemans that are less expensive, a little wider, and suffer less from vibration. Buell OEM #'s:N0151.2A8 Mirror, Left $19.60 USN0162.2A8 Mirror, Right $19.60 US (Pricing as of 1/05) guzzipower.com - Wider OEM Mirrors '02+ Le Mans 2 1
docc Posted March 25, 2024 Posted March 25, 2024 OEM PARTS Original compound front and rear brake pads GU01654630 front (2 pair required) GU27654610 rear ( 1 pair) REPLACEMENT PARTS Brembo Source: OPP Racing , Washington state, USA/ BC, CAN Brembo Part# 107670810 fronts https://www.oppracing.com/product_display/30979-brembo-oe-brake-pad-set-ferit-id-450ff- organic- for-206800xx-209230xx-caliper-shape-m-107670810/ Brembo Part# 107268625 rear https://www.oppracing.com/product_display/30967-brembo-oe-brake-pad-set-ferit-id-450ff-organic-pad-kit-p32f-7mm-thick-107268625/ Other Comments: This is a reliable Brembo parts dealer. Most Moto Guzzi dealers or Guzzi suppliers have superseded the original brake pads with substitutes of various manufacturers and compounds from GF to SHH. Rotor damage can be an issue. These are the original FF compound "black backing" pads matched to our rotors from Brembo . 2 3
audiomick Posted January 10 Posted January 10 (edited) Fuel filter. I have not taken the trouble to look for recommendations here for the in-tank fuel filter, but this just came up from a very reliable source in the German forum, so I thought I'd pass it on. Note: I HAVEN'T TRIED THIS OUT!. I'm just passing on something that I read. The man in question wrote that he has used this filter many times on various Guzzi models with an in-tank filter, and on being asked by me claimed that it was also good for the V11 models. The stated model name is Mann MWK44 I wont post any links, because I got lots of hits from a simple search. Price seems currently to be around €15,-. For comparison, someone else posted this link to a filter from Wendel in Berlin (a very reliable and reputable supplier) https://wendelmotorraeder.de/benzinfilter-stelvio-ab-11_641277-p-6100765.html?ref=expl €76,- and a couple of cents. Edited January 10 by audiomick 2
