It is certainly hard enough to get tools on that I went with "NyLoc" nuts on the upper fasteners.
  On 2/10/2022 at 11:26 PM, docc said:
So here are a few images that may help. It is very hard to get images of it in situ.
LowRyter's installation from the right looking forward:
MySport looking down from the left side (tank, airbox, starter, all removed), barely visible beyond the injector:
From the left through the "throttle rod tunnel":
The mounting tab, on the early RedFrame only, seen midway on this frame turned bottom side up:
Screen%20Shot%202020-11-15%20at%206.29.2
One more from the left (tank and airbox removed) :
Expand
Crap, my frame does not have any upper attachment means/nothing the plate can bolt onto...it seems the bracket will be no good for my frame.
  • Sad 1
Yes, I would think you could see the edge of the frame tab from that angle. What is the month-year of the build date on your left-side headstock tag, @laurent?
Expand
It says 9-2000
My 3/2000 Sport has the tab. Apparently, it was eliminated for the 2001 >black< ShortFrame "Rosso Mandello."
Your Greenie Sport is a 2001, @laurent?
If you you feel up along the bottom of the Spine? Is the tab there?
Expand
I am feeling along the bottom of her spine....remember she's naked..sorry couldn't help it. No definitely no tabs along the bottom of the spine :(
on the id plate it says 9-2000
Is your Sport titled as a 2001, then?
If I recall correctly, this is the first RedFrame we have seen without the Frame Plate mounting tab.
Also, IIRC, our member @Tinus89 added a frame tab to his 2001 Rosso Mandello to install the mid-frame support plate . . .
Expand
Yes it is titled as a 2001
Expand
My tag is marked 6-2000 and my frame is equipped with the tab. I guess we've already figured out the early 2000's was not a good time for Moto Guzzi! What a bummer. @laurent I would be happy to try and pull some good measurements for you as I have an unmolested tab with nothing mounted to it presently. Let me know.
Very weird. I thought the tabs were carried over from the Centauros and we’re there until the later V11 long frame. Every factory parts diagram I have seen for the red frame era bikes shows the frame with the tab and the bracket. An anomaly.
My 01 Greenie tittled 01 with # have no sign of a bracket, or the painter did a great job removing any signs of a bracket . IPA time here Cheers Tom.
Sent fra min SM-A525F via Tapatalk
