The gearbox breather, has anyone had this apart to see what it looks like, and took pictures. I don't have a spare to take apart, I would like to see the guts of it and see if it is possible to clamp a hose/tube to it and the prevent the ingress of water to the gearbox. Maybe I can then patent this idea to Guzzi.
Cheers.
I didn't take it apart, but you can take the hood off, and clamp a hose on it. Only the part to clamp on is not to long. I plan to make a new thingy from aluminium can''t be that hard.
Do you recall the size and pitch of the threaded end of the brass fitting you used?
al
No , I never have that type of info :lol: I jez took the breather into the hardware store & went to the brass fittings in the plumbing section, you know where they keep all that stuff for your well :luigi:
Guest northend
If it was a pipe thread type nipple it wouldn't be any larger than what they call 1/8 inch. Also I would bet that any rear wheel drive automotive axle vent would work on a piece of hose. I'll check it out when I put my new windshield on tomorrow and let you guys know.
Later.........Jeff H.
