Help, new Stucchi crossover
Guest WildJackal
You know how the stock headers have a bolt/plug (3/8 in. ?) screwed into the bottom where they straighten to go into the crossover? I don't know what it would be used for .... tuning? Blowing out the carbon?
I just got a new Stucchi crossover. I went to mount it and it has a hole for a bolt like that up by the mounting hanger bracket. The only problem is there is no bolt/plug included. It is bigger than the header bolt/plug holes.
Has anyone seen this before? Is this a good thing? Or just somthing to disrupt flow.
For now, I have a holed crossover ... :huh2:
Guest WildJackal
As Emily Latella would say .... nevermind. I looked through the packing and found the bolt/plug. The hole is for bikes with a Lambda sensor. So, don't throw that packing away until you have all the pieces. The bolt didn't want to screw in. I wasn't able to seat it and it won't come out. I think the bolt hole was warped some when they welded it in.
Another question: What to do with the breathers that fed into the canister kludge I will be tossing. The gas tank overflow can stay but should I plug the manifold tubes?
Thanks
Guest Brian Robson
Absolutely you need to plug the inlet holes. These are used to help balance the throttle bodies. Use a small allen key bolt.
Guest Steve in VA
WildJackal -
What mufflers are you running?
How do you like the Stucchi crossover?
I am struggling to decide if I want one, but I swear my V11S is loud w/ those Mistral cans.
I want to get a custom PC III map, so I need to decide.
Guest WildJackal
The Stucchi was my first mod, I don't have cans. I had a hard time parting with $300 for a "piece of pipe", but I had the 4-5Krpm stumble and I figured I would buy the Stucchi eventually.
I am elated with the results. The bike is much happier at the low to mid rpm range. I thought the bike was running fine everywhere but 4-5K, but in retrospect it was rough .... not happy to hold a steady rpm. It is sweet now. I still want a PCIII and cans when I have the coin, but the Stucchi was a great first mod. The bike is truely more enjoyable to ride. Smiles all over! :bike:
Guest Steve in VA
I thought I was te only one w/ a Jackal and a V11S, esp. 2000's both.
