Guest motor72
My 2003 Lemans has a serious case of tank suck. Would this repair be covered under the warranty? I'm looking for an excuse to travel the 3 hours to the nearest dealer.
Naw, just take the check/tip-over valve off..... not worth a "warantee trip".
Now, if your tank has cracked paint, or other failures/damage caused by the tank suck, then I would report that.
...but just take the valve off yourself. It's a 15 minute job, if that :P
al
I just removed mine....it's real easy to pull! I was able to tilt up my tank and do it without removing the fuel lines. Now my LeMans doesn't suck any more :thumbsup:
:rolleyes:
Guest motor72
Done. No more sucking. I also removed the emission equipment while I was at it.
If anyone from the EPA is monitoring this, I was only kidding about the emission equipment. Ride safe.
