LowRyter Posted September 19, 2022 Posted September 19, 2022 I'm guessing there are few folks here that have Pinlock anti-fog inserts that attach to the helmet visor. I was cleaning my my visor last week and broke a couple of pushpins. I was able to find a supplier on the 'web. They did cost $10 but got to me a 4 days.https://www.ebay.com/itm/304591910462 2
docc Posted September 19, 2022 Posted September 19, 2022 Riding through the drizzling fog, back-and-forth over the TN/NC Cherohala Skyway at SSR XVIII, wreaked havoc with the faceshield visibility on my new-ish AGV SportModular. The event made me wonder how much the Pin-Lock might have mitigated that. Otherwise, I've heard they can be a hassle . . .
Chuck Posted September 19, 2022 Posted September 19, 2022 They make a difference.. but as you said, they are a hassle. I just crack it open when necessary and leave the pinlock at home. To me, they seem best when it's cold. 1 1
Tomchri Posted September 19, 2022 Posted September 19, 2022 This time of the year, it's a must, 7c tonight, and snow sticks up already Cheers Tom. 1
LowRyter Posted September 20, 2022 Author Posted September 20, 2022 2 hours ago, docc said: Riding through the drizzling fog, back-and-forth over the TN/NC Cherohala Skyway at SSR XVIII, wreaked havoc with the faceshield visibility on my new-ish AGV SportModular. The event made me wonder how much the Pin-Lock might have mitigated that. Otherwise, I've heard they can be a hassle . . . It works. I'm not sure what the hassle is? The pinlocks are preinstalled on Shoei helmets. I suppose that you could bugger the shield in your AGV by spacing the holes wrong? 1
LowRyter Posted September 20, 2022 Author Posted September 20, 2022 1 hour ago, Tomchri said: This time of the year, it's a must, 7c tonight, and snow sticks up already Cheers Tom. It's freaking 95 degrees here today. Too hot to light the grill. But you appreciate the Pinlock? Works in rain and cold. 1
docc Posted September 20, 2022 Posted September 20, 2022 15 hours ago, LowRyter said: It works. I'm not sure what the hassle is? The pinlocks are preinstalled on Shoei helmets. I suppose that you could bugger the shield in your AGV by spacing the holes wrong? This AGV is PinLock capable. So was my last (ever) Shoei. I've lust "just" never used the feature, so don't know what to think of the advantages/disadvantages. 1
LowRyter Posted September 20, 2022 Author Posted September 20, 2022 13 hours ago, docc said: This AGV is PinLock capable. So was my last (ever) Shoei. I've lust never used the feature, so don't know what to think of the advantages/disadvantages. Did your helmets come with the inserts and pushpins installed in the visor? If so, just try it out. It does work. I'll agree that venting the helmet by slightly opening the visor works too. The problem with all my helmets, is that once I get over 40mph the visor shuts and then it fogs up. I remember a few years ago, I was heading back from Arkansas, a cold front came in and it was 28 with snow furries. I had anticipated the weather and brought winter gear, all to the envy of my fellow riders going back to Texas. Anyway, I tried to vent the helmet, it was absolutely miserable. I rode about an hour and half and got to Springdale and stopped at McDonalds for breakfast. I come up with a solution by folding some napkins and stuffing them in user the visor. It worked. By the time I got home it was almost 50 degrees and a great ride there after. My issue with this helmet is that I just left the insert in full time. So when I took it apart to clean it, the brittle pins broke. It also has a little distortion, I don't it was due to use or just a small consequence. After all, two different viewing layers, it's going to have some distortions. BTW Docc, not quite what I "lust" for. 1
80CX100 Posted September 20, 2022 Posted September 20, 2022 My Shoei GTAir has pinlocks and an anti fogging sheet(s?). I've never gone to the trouble of figuring out how they work and using it; I just crack the visor open a bit as needed. In warmer weather that opened visor has let a wasp fly inside my helmet, that made for a little excitement and a quick stop,lol. In cold weather bugs usually aren't an issue. In real cold weather, I wear a thin balaclava that I pull up over my mouth & nose, it aids a lot in managing the fogging issue. fwiw 2
Tomchri Posted September 20, 2022 Posted September 20, 2022 And usually a new visor with pinlock every year. Then normaly no need to take the pinlock out. If I do, I lift it up from the senter of the lock. Cheers Tom.
Chuck Posted September 21, 2022 Posted September 21, 2022 Quote After all, two different viewing layers, it's going to have some distortions. That is my issue with them. It doesn't bother most people, but optical distortion really bothers me for some reason. For instance, I can't do VR.. I'll get nauseous.
cash1000 Posted September 22, 2022 Posted September 22, 2022 I've got a Shoei GT Air with pinlock fitted fulltime. Couldn't live with out it. With glasses at least only 1 surface is fogging up not 2. What does everyone use to clean their visors? I use hot soapy water then spray outside with Ipone so rain beads off - Rain Repellent VISOR RAINOFF | IPONE . 1
