LaGrasta Posted September 20, 2022 Posted September 20, 2022 https://www.ebay.com/itm/275220524702?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20220405142716%26meid%3D2b1f22fcd16249e591b79064642f691d%26pid%3D101506%26rk%3D4%26rkt%3D25%26sd%3D154753706283%26itm%3D275220524702%26pmt%3D1%26noa%3D0%26pg%3D2563228%26algv%3DSimplAMLv9PairwiseWebMskuAspectsV202110NoVariantSeedNoPLX&_trksid=p2563228.c101506.m1851&amdata=cksum%3A2752205247022b1f22fcd16249e591b79064642f691d|enc%3AAQAHAAABEAzdIKOcP6rVYsexH8mCu6bA2DY6ElM67JKComxjxAnyT9vOhsWu88eBePRdeUyezGJzQOV7Xuwj4hElfgg5l6ssunGEbeSHs%2FdNfJP3vXqMVgjO6DbHIgeA2W%2Bho8I5%2BYHZPU%2B5xZ4OXCJhpIUjzJg4618Tdvsc%2FeXFEbyAdfRq2%2FmoxARgx8iiVmZ4P%2FPxIkgxh2rJBoEWa%2FjnUZs68IsSylJnsJGJmfepcc6N53TEUz1yjpjUvjj%2BBl4r1IUZL1IkRwBIw0CrnpppipKronlt7hmqFPOk70al7JidbKQf0aUZZah8JeTsXSXm7yMhEwv3jW65W4XsrfxlmHfdXNBEIM5C9JK7L%2FYtE0%2BRYQUp|ampid%3APL_CLK|clp%3A2563228&epid=27042835775 I know about remapping and such. My 2010 V7 has a DynoJet PowerCommander, with GuzzitTech mapping. This one I fell upon this morning, with a dial, is what exactly? Same brand, but more traditional, no dial. https://www.ebay.com/itm/275220524163?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20220405142716%26meid%3D2b1f22fcd16249e591b79064642f691d%26pid%3D101506%26rk%3D10%26rkt%3D25%26sd%3D154753706283%26itm%3D275220524163%26pmt%3D1%26noa%3D0%26pg%3D2563228%26algv%3DSimplAMLv9PairwiseWebMskuAspectsV202110NoVariantSeedNoPLX&_trksid=p2563228.c101506.m1851&amdata=cksum%3A2752205241632b1f22fcd16249e591b79064642f691d|enc%3AAQAHAAABEAzdIKOcP6rVYsexH8mCu6bA2DY6ElM67JKComxjxAnyT9vOhsWu88eBePRdeUyezGJzQOV7Xuwj4hElfgg5l6s7hG9bYz6cLHpP53k62KpjDnVs%2FPrbshS4ufcNaTpFt7Un8JvqSdQrvqQ59qywbmxUDJDzN1Ty%2F%2BSs8QnbxSV2icp7RG6Fet56LOwSRafvrTDE8tUm%2FGHbenr4fB7w5QVIIxuJiiyXdWbmwJKDdd%2Fsgpm2tFfh5A1B4WGG4itFyR4vBy1NLq2K4ApUqtBH%2BgutZJw%2B0d3qS9KTFHYs%2Fjq1jx0O%2FCG0QghHa62fQk7IJvY6L1W9dyKtoque0EiFJ7RgRE3HtC%2FlOt0EePlBtrAS|ampid%3APL_CLK|clp%3A2563228&epid=23043789470
4corsa Posted September 20, 2022 Posted September 20, 2022 Oh geez, better hope Pete doesn't see this!Sent from my Pixel 4a using Tapatalk 1 4
pete roper Posted September 20, 2022 Posted September 20, 2022 It's a sensor fooler. Don't waste your money. 3 1
docc Posted September 20, 2022 Posted September 20, 2022 12 minutes ago, pete roper said: It's a sensor fooler. Don't waste your money. What that actually means in PeteParlance: "Those arsed-crappers are for knuckle-dragging shaved-apes that couldn't get an antelope fart into their intake without squeezing it through their nose. " [I may have paraphrased a bit, there . . . ] 2 5
pete roper Posted September 20, 2022 Posted September 20, 2022 Actually if I could of been bothered I would of described it as a magical device that relies on the catalytic effects of wishful thinking and it's interaction with traces of powdered unicorn horn within the device to completely f*ck up the fueling and contribute to greatly accelerated engine wear but I couldn't so I won't......... 2 6
docc Posted September 20, 2022 Posted September 20, 2022 9 minutes ago, pete roper said: Actually if I could of been bothered I would of described it as a magical device that relies on the catalytic effects of wishful thinking and it's interaction with traces of powdered unicorn horn within the device to completely f*ck up the fueling and contribute to greatly accelerated engine wear but I couldn't so I won't......... See there? Even my best attempt at paraphrasing will never compare to Genuine PeteParlance. [I thought the "antelope fart" was pretty clever, though. It's like an accelerator pump for powdered unicorn horn . . .] 1
4corsa Posted September 20, 2022 Posted September 20, 2022 Can't believe the "just load the Meinolf map via guzzidiag" was omitted.Sent from my Pixel 4a using Tapatalk 1
docc Posted September 20, 2022 Posted September 20, 2022 3 minutes ago, 4corsa said: Can't believe the "just load the Meinolf map via guzzidiag" was omitted. Shoot, I should get extra moderator points for not posting, "First, perform a meticulous Decent Tune-up." Until now . . . 2
LowRyter Posted September 21, 2022 Posted September 21, 2022 I guess you guys will defend that the PC on my Greenie is OK? I've never touched.
pete roper Posted September 21, 2022 Posted September 21, 2022 Back in the day a PC was just about the only option. It worked, pretty crudely, but it worked. I had one on the Mighty Scura but only because it came with it. Nowadays though the mapping for the 15M and 15M-RC are an open book. Why would you arse about with an add-on widget when you can access everything in the map? Not just the fuel and spark. 1 1
GuzziMoto Posted September 21, 2022 Posted September 21, 2022 13 hours ago, LowRyter said: I guess you guys will defend that the PC on my Greenie is OK? I've never touched. I am a firm believer in "If it ain't broke, don't fix it". I would not remove a Power Commander if the bike is running just fine. But if the bike stops running fine, removing it would be pretty high on my list of things to do to resolve the issue. In fact, I will likely be removing the Power Commander on the wife's V11 shortly as it has some issues with the way it runs. I fear the Power Commander has starting acting up. Or not, could be something else. But removing the Power Commander removes a potential source of problems. More than a few people have experienced their Power Commander failing. Electronic devices do that sometimes. Or it could also be the TPS getting itchy and scratchy. 2
LaGrasta Posted September 21, 2022 Author Posted September 21, 2022 I wasn't interested in purchasing this, or even messing with anything in this area (maps, etc). I haven't got my dormant V11 running yet, so I have no idea if it needs attention in this area at all. I just came across this device, thought it looked suspicious, thus my question. 2
