RichP Posted October 1, 2022 Share Posted October 1, 2022 Hi, I've a new 2002 V11 LeMans which has about 8K miles on it. It runs well and rides great but has an oil leak on the right hand side which seems to be coming from the plastic pipe that goes from the airbox to the throttle body. It drips down onto the transmission on the plug that is behind the speedo connection. I've done some research and it seems like it might be a crankcase ventilation issue, but before I tear into the bike I thought I'd ask if anyone has had the same issue. and how you fixed it. Thanks in advance for any assistance. Rich 69 V700 74 Eldo Police 02 V11 LeMans (Champagne) Link to comment Share on other sites More sharing options...
docc Posted October 1, 2022 Share Posted October 1, 2022 Most likely leak source: 3 2 Link to comment Share on other sites More sharing options...
footgoose Posted October 1, 2022 Share Posted October 1, 2022 I've had similar issues on two V11. Both were the crankcase ventilation tube. The pasta they are made of doesn't like oil and heat so they disintegrate. The leak can start at the top clamp and run down and drip on various cables and such and can appear to come from 'wherever". The most common spot to fall apart is at the lower hose clamp and then drips down the sides to wherever it wants to go. 3 1 Link to comment Share on other sites More sharing options...
ScuRoo Posted October 1, 2022 Share Posted October 1, 2022 Good info fella’s These tips are helpful Made memo to myself to check state of my own 👍😎 2 Link to comment Share on other sites More sharing options...
RichP Posted October 1, 2022 Author Share Posted October 1, 2022 Thanks, I'll order a new breather hose asap. Appreciate the input. Rich Link to comment Share on other sites More sharing options...
footgoose Posted October 1, 2022 Share Posted October 1, 2022 replacing it is a win win. Even if that isn't the leak source, the original tube will fail so, good to rule it out. 3 1 Link to comment Share on other sites More sharing options...
