Hello all ! Happy Friday.
I have a quick question.
I would like to try to mount a V7 ( modern v7 ) gas tank on my V11.
can I use the fuel pump of my V11 inside the v7 tank? Will it fit / work?
asking in case someone been there before me .
also if I wanted to use a gas tank from a carburated Guzzi….
can I use the same set up like the California EV ( for example) with the external  fuel pump ?
I don’t see why I should not be able to use an external fuel pump …. But just asking since I am missing something.
 Thank you
m.
 It will or it won't . No tellin' .
 Also , I hope you are considering how it will look ?
There's no quick answer to your questions, but you should consider that pressure hose (& probably pump) designed for total immersion in fuel are different from external components.
Mounting a pump inside a tank will be tricky if the tank is not designed for it.
Power and fuel passthroughs across the tank floor need a fuel tight design.
Also the tanks you mentioned were made for a conventional frame, not a spine frame, so fit could be a challenge.
