red lion Posted December 18, 2022 Share Posted December 18, 2022 How do you adjust the throttle slack on the V11. I don't see an adjuster on the cable like on other bikes? Link to comment Share on other sites More sharing options...
docc Posted December 18, 2022 Share Posted December 18, 2022 Early and later differ slightly. At one time, the Moto Guzzi parts system had the part number wrong for the early (1999-2001) V11 and you would receive the later (bent tube) cable. Its adjuster is obvious: On earlier V11, the connection is straight and you pull back the rubber boot to expose the cable adjuster/ lock ring. Mine shows alot of slack taken up. I like my throttle tight. Like the shortcut thru Nayook to Noojee . . . 1 Link to comment Share on other sites More sharing options...
docc Posted December 18, 2022 Share Posted December 18, 2022 Also, take time to inspect the cable exit to the bell crank. An angle like this will eventually fray the cable: Angle the bracket for a straight shot: 7 Link to comment Share on other sites More sharing options...
docc Posted December 19, 2022 Share Posted December 19, 2022 21 hours ago, red lion said: How do you adjust the throttle slack on the V11. I don't see an adjuster on the cable like on other bikes? Sorry about all the noise I made @red lion . . . Short answer: 1 2 Link to comment Share on other sites More sharing options...
red lion Posted December 19, 2022 Author Share Posted December 19, 2022 Your information was very helpful. Thanks 1 Link to comment Share on other sites More sharing options...
