cash1000 Posted January 22, 2023 Author Posted January 22, 2023 On 1/21/2023 at 10:44 AM, cash1000 said: Just heard back from Vince. The failed bearing was rear one on upper lay shaft. Can any one point out in parts diagram which is the bearing that failed? Yup my bad wrong page
cash1000 Posted January 22, 2023 Author Posted January 22, 2023 On 1/21/2023 at 12:37 PM, Baldini said: It's the rear bearing on the upper lay shaft. #23 in this drawing. Part# 92 20 12 25 (ball bearing 25x52x15) Many thanks for posting correct page 1
audiomick Posted January 22, 2023 Posted January 22, 2023 On 1/21/2023 at 1:45 AM, fotoguzzi said: ... but don’t you have to be a paid member? (at Guzzitek.org) No. To cross-check, I just loaded this manual down to my laptop: https://guzzitek.org/gb/ma_us_uk/1100/V11_1999-2003_Atelier(Compil-GB-D-NL).pdf No costs, no membership, just "save to ..." using the function for that in the browser. There is a place for donations on the site, but using the site is free. I should donate actually. The amount of times I've used that site myself or linked to it, I "morally" owe the guy about 10.,000 bucks. 1 2
cash1000 Posted January 26, 2023 Author Posted January 26, 2023 Pick up completed gearbox yesterday. Great service from Vince. 2 weeks earlier than I expected and cheaper Got some painting to do before I re fit. Paint flaking off from top & bottom of gearbox plus some touch ups to swingarm etc 2 1
MartyNZ Posted January 26, 2023 Posted January 26, 2023 1 hour ago, cash1000 said: Pick up completed gearbox yesterday. Great service from Vince. Do you have a drain bung with a magnet in it? Just in case there is still a few bits in there. 3
cash1000 Posted January 30, 2023 Author Posted January 30, 2023 On 1/26/2023 at 6:19 PM, MartyNZ said: Do you have a drain bung with a magnet in it? Just in case there is still a few bits in there. Yup. When I removed it to drain oil it had metal fragments attached to it. Not a nice sight 1
cash1000 Posted February 5, 2023 Author Posted February 5, 2023 I'm having trouble refitting the gearbox. I can't get the gap between the gearbox & engine cases to close up. Is it that the splines on the gearbox are not meeting up with those on the clutch plate? The manual talks of a clutch alignment tool. Do I need this?
docc Posted February 5, 2023 Posted February 5, 2023 Yes, the clutch parts must be aligned when the clutch is assembled . . . Then the gearbox input hub can be jiggled to fit into the clutch assembly.
cash1000 Posted February 5, 2023 Author Posted February 5, 2023 18 minutes ago, docc said: Yes, the clutch parts must be aligned when the clutch is assembled . . . Then the gearbox input hub can be jiggled to fit into the clutch assembly. Thank's Doc. Makes total sense when you think about it. Out come's gearbox again
docc Posted February 5, 2023 Posted February 5, 2023 7 minutes ago, cash1000 said: Thank's Doc. Makes total sense when you think about it. I seem to recall that a spare gearbox input hub will serve as a clutch alignment tool? What clutch/flywheel combination did you go back with?
cash1000 Posted February 5, 2023 Author Posted February 5, 2023 5 hours ago, docc said: I seem to recall that a spare gearbox input hub will serve as a clutch alignment tool? What clutch/flywheel combination did you go back with? I'm reinstalling original flywheel & clutch. Plan is add a V85TT to fleet to do any long distance riding on so mileage on V11 will be less. I've used a vinier caliper to centre clutch plate. Have another go at gearbox tomorrow 1
docc Posted February 5, 2023 Posted February 5, 2023 5 hours ago, cash1000 said: I'm reinstalling original flywheel & clutch. Plan is add a V85TT to fleet to do any long distance riding on so mileage on V11 will be less. I've used a vinier caliper to centre clutch plate. Have another go at gearbox tomorrow 4 hours ago, pete roper said: Is this a single or twin plate clutch? Okay, then, the original single plate clutch and aluminum flywheel of the Rosso Mandello . . . 1
pete roper Posted February 5, 2023 Posted February 5, 2023 Which hub does the new gearbox have? If it's a twin plate hub it may be fouling on the pressure plate of the clutch. 1
cash1000 Posted February 5, 2023 Author Posted February 5, 2023 Not a different g/b Vince repaired original one. G/b proving stubborn to refitt. I'm obviously not getting splines lined up. I can get cases 2mm apart. I can move alternator nut. If I tighten nuts to join cases just a couple of turn's then I can't move alternator nut. If I ensure gap in between cases is the same all round then g/b should be lined up with clutch splines. I should then wiggle alternator nut untill splines join. In theory.
