#1, try well known relays. #2,  extra start relay.  It's all here on the forum. Very seldom some strange things going on, not been mentioned here before.   What I have learned about the V11, WHAT a forum, THANKS.
Cheers Tom.
  • Like 4
Yes, I also have learned a lot here. I'm working through it myself because I want to understand it. I'm documenting it in the hope that this might help someone else understand what is going on better, and because writing helps me think it through. :)
  • Like 3
Cheers Tom.
This . .  . +1
Ah , yes, a 2002 V11 would be prone to Startus Interuptus .  You have good indications to clean/service your Ignition Switch and make plans for the additional @Kiwi_Roy Relay for the starting . . .
  • Like 3
10 hours ago, docc said:
clean/service your Ignition Switch...
Had that apart about six months ago. Someone broke the back off it whilst it was parked on the street. I mentioned it here at the time. You may recall having seen this photo here already:
Nevertheless, I'll be taking that apart again some time soon. There is still a small problem to deal with (which doesn't affect the operation...)
As already mentioned, the thoughts are already churning regarding an additional relay. :)
