Oil light on at idle
Guest Rustleo
V11 Le Mans 02. At idle the oil light would flicker until revved up a little. It eventually began to stay light longer at idle and then became a nuisance. I replaced the oil pressure sending unit at the top of the motor. No good. I dropped the pan to shim the oil pump spring and found when removing the filter that 1/2 of the rubber seal on the filter had broken and was allowing a bleed off at idle causing the oil light to come on at idle. Cause unknown, faulty rubber? Moto guzzi filter. I paid close attention the the condition of the new filter while installing and have had no further problems. Rustleo
Thanks for the tip. I've converted to the 'if the oil light is on, then trouble is brewing' camp.
cheers,
Jason
Guest Rustleo
Yeah, I guess they put that light there for a reason.......
