audiomick Posted April 17, 2023 Posted April 17, 2023 Ah, now I see nuts. Expensive, methinks, but very, very pretty.
docc Posted April 18, 2023 Posted April 18, 2023 16 minutes ago, audiomick said: Ah, now I see nuts. Expensive, methinks, but very, very pretty. Yep, I figure using my existing "spacer" and adding the expensive washer and nut to the Moto Guzzi cadmium bolt will set me back a whopping $10US including the shipping costs. 1
audiomick Posted April 18, 2023 Posted April 18, 2023 Don't break the bank. There is beer to be bought as well. 1
docc Posted April 19, 2023 Posted April 19, 2023 So, as pretty as the Moto Guzzi bolts are, cadmium plated, these nuts&washers (two days from McMaster-Carr) have a stunning black finish. That they look like powder coat is confirmed seeing they are Black Luster®, a Columbia Coatings powder coat product. 6
LowRyter Posted April 20, 2023 Author Posted April 20, 2023 I'm getting the Greenie back tomorrow. Rode it today before I rode the Mandello. It's pretty stout, broken bolt replaced, new tires and brakes, Brembo levers (free) and dyno tuned .... wont outrun the Mandello in a straight line, right now I'd take the Sport in the twisties. So far as a beauty contest, Green wins. Got the EV back, runs better than in many years. I'll be Guzzi @100% tomorrow or the next day. 4 1
MartyNZ Posted May 28, 2023 Posted May 28, 2023 On 3/19/2023 at 9:18 AM, al_roethlisberger said: Shouldn't the nylok/nylock nut really be replaced after one use as well, especially for something that crucial, or is that overkill? It is a good idea to replace nylock nuts after use if in a critical application, but there is an alternative. A check for "Run On" torque can tell you if the nut locking function is still effective. I'd call my Rear Axle nut critical, and the locking is a bit marginal, so one day... 1 1
al_roethlisberger Posted May 28, 2023 Posted May 28, 2023 In theory the bolt I ordered is still on order ...not critical timing, so we'll still see.
al_roethlisberger Posted May 28, 2023 Posted May 28, 2023 On 4/19/2023 at 7:29 PM, docc said: So, as pretty as the Moto Guzzi bolts are, cadmium plated, these nuts&washers (two days from McMaster-Carr) have a stunning black finish. That they look like powder coat is confirmed seeing they are Black Luster®, a Columbia Coatings powder coat product. Are the bolts the correct size without modification? Do you have the McMaster-Carr part number for the bolts in case anyone needs them?
docc Posted May 28, 2023 Posted May 28, 2023 On 5/28/2023 at 7:57 AM, al_roethlisberger said: Are the bolts the correct size without modification? Do you have the McMaster-Carr part number for the bolts in case anyone needs them? The cadmium plated bolts are the correct Guzzi part GU01357731 from Harpermoto. @Curtis Harper still has a few on hand. Always best to call Curtis (and mention V11LeMans.com). I could not find the correct shank length (thread length) bolt at McMaster-Carr, but sourced the powder coated, 10.9 hardness, nuts and washers there. Those part numbers and links are in this post: 1
