red lion Posted April 2, 2023 Posted April 2, 2023 Gas is leaking on my 2000 sport where the fuel regulator and gas tank meet. Is there a replacement gasket available, And who would have one? I have not removed it from the tank yet.
gstallons Posted April 3, 2023 Posted April 3, 2023 Do you have a parts catalogue ? Maybe go to harper's website and see , too 1 1
red lion Posted April 3, 2023 Author Posted April 3, 2023 I looked at AF1 racing and for fuel tank they did not even show the fuel pressure regulator. 1
docc Posted April 3, 2023 Posted April 3, 2023 Parts Catalog, Engine, Code 34.28, Fuel supply, Page 56 / 83 #21 - GU90714103 Gasket 1
red lion Posted April 3, 2023 Author Posted April 3, 2023 It looks like 22 meets with the tank. #23 looks like the gasket. What part # would that be and is it available? Also where to purchase the gasket? 1
gstallons Posted April 3, 2023 Posted April 3, 2023 Any MG dealership can answer those questions for you .
docc Posted April 3, 2023 Posted April 3, 2023 9 hours ago, red lion said: It looks like 22 meets with the tank. #23 looks like the gasket. What part # would that be and is it available? Also where to purchase the gasket? Ah, there you go. Two "gaskets" then and you're after #23. #23 = GU90706116 O-ring Check the usual US sources: MG Cycle, Hapermoto, AF1Racing, Cadre Cycle. If you take the part off, your local auto parts store "might" be able to suss out the fitment.
al_roethlisberger Posted April 3, 2023 Posted April 3, 2023 Yes, 23 is just an o-ring. You can source this at any auto parts store, or of course online. You'll need an o-ring that is specifically resistant to fuel and oil, which is common. BTW, ignore the "blue stuff". That is leftover special fuel resistant sealer I had used many years ago during some tank plumbing experimentation. 2 2
al_roethlisberger Posted April 3, 2023 Posted April 3, 2023 Here are the general approximate dimensions of the o-ring. I put the caliper in the groove and it reads about the same too. You'll almost certainly buy an assortment of o-rings. So just find the one in that assortment that fits best. 1 2
MartyNZ Posted April 6, 2023 Posted April 6, 2023 When I had tiny leaks on my tank, I went to replace the O-rings under the flange fittings. I noticed that the screw inserts that attach the flange to the tank had pulled out a tiny bit, creating bulges in the tank plastic. This meant that the clamping of the O-ring was reduced so allowing leaks. Running a file across the tank insert face reduced the bulging at the inserts without touching the sealing face. 1 2
audiomick Posted April 6, 2023 Posted April 6, 2023 That indicates that one should avoid over tightening those screws, doesn't it? 2
red lion Posted April 7, 2023 Author Posted April 7, 2023 None of the moto guzzi suppliers had the O ring in stock. I found it at napa auto parts. All's well now. Thanks 2
