Hey all, took a tumble in December on the right side, replacing mirrors, engine head crash guards and my rear brake lever...and boy, is it ON!
Even after CRC Freeze-off!
Brake bar? What am I missing here?
Nevermind....got here loose...breaker bar it was! Love this bike!
Well, piston fell out...how do I get her back in???
I used a 8mm hex socket & it broke loose w/no trouble. Use a good ratchet & cheater pipe if you need it .
The rod fell out of my rear slave cyl ... how do I get it back in????
1 minute ago, gstallons said:
Hmmmm. Explain . did you lose brake fluid too ?
Yes, a tiny bit came out
The piston rod can fall out, but if no brake fluid follows, then just put it back. If fluid comes out then you have a different problem
Maybe you dropped  piston only . can you reinstall ?
Geez...was a simple job...now...man...
I'm trying...
