Art Posted May 30, 2023 Posted May 30, 2023 I've got a few things to fix while waiting for a Voltage regulator to be delivered. Both coils are flopping around in the frame. They appear to have rubber mounts that have broken. Should be easy to zip tie down with some bits of rubber. Is there anything to watch out for such as cooling? 1
docc Posted May 30, 2023 Posted May 30, 2023 I put my isolation blocks back together with a toluene based contact adhesive (commonly available as "Goop" or "Shoe Goo" here in The States). Replacement isolation blocks can probably be had from McMaster-Carr. 5
guzzler Posted May 30, 2023 Posted May 30, 2023 Yep I had the same issue years ago and they were glued back. Not had any issues since but don't know what glue Rob used. Cheers 1
Pressureangle Posted May 30, 2023 Posted May 30, 2023 For what it's worth, when I have to glue something important that's rubber- particularly to metal- I use 3M weatherstrip & emblem adhesive. I can't say I've had failures with Shoe Goo or Gorilla Glue, but I feel better using a product with these specific materials in mind. 4
