Art Posted June 1, 2023 Posted June 1, 2023 Wandering about the site like a rookie I've noticed a few high mileage bikes. Be interesting to know how many. Would be even better to know how many miles before a top end rebuild, full rebuild, clutch. etc. If anyone's keeping track, just point the way. Thanks 3
docc Posted June 1, 2023 Posted June 1, 2023 After this last valve adjustment (no changes to the lash), I did have to cave in and replace the right side, original valve cover gasket. I suppose I should go ahead and do the left side . . . 2 5
docc Posted June 1, 2023 Posted June 1, 2023 Seriously, other than Relays, Battery, and Tune-up: the three most neglected areas on V11: > Rear drive: far right side needle cage. > Sidestand fasteners, both, but especially the high torque large bolt. > Charging system failure (ungrounded regulator, melting 30 amp fuse, broken stator wires). 7
docc Posted June 1, 2023 Posted June 1, 2023 Oh, well, yes . . . there is the matter of greasing the front U-joint. Especially on the the early RedFrame Sports . . . So much of this is in the Tank Off Maintenance Checklist and Wheels off Maintenance Checklist As to major mechanical rebuilds, that hasn't turned out to be of the most concern, as far as I have seen. 3
Art Posted June 1, 2023 Author Posted June 1, 2023 I did read that posting. As if putting on a new tire wasn't bad enough. 1
MartyNZ Posted June 1, 2023 Posted June 1, 2023 6 hours ago, docc said: Seriously, other than Relays, Battery, and Tune-up: the three most neglected areas on V11: > Rear drive: far right side needle cage. > Sidestand fasteners, both, but especially the high torque large bolt. > Charging system failure (ungrounded regulator, melting 30 amp fuse, broken stator wires). Also the parts that might look ok now, but should at least be in your bin of "parts that I may need soon": > Crankcase Vent hose from bell housing to the top of the spine > Hose couplings between the throttle bodies & the intake spigots > TPS Sensor > Phase/Crank position sensor > Oil pressure Switch > The improved gearbox shifter return spring 4 2
Tom in Virginia Posted June 1, 2023 Posted June 1, 2023 8 hours ago, docc said: Seriously, other than Relays, Battery, and Tune-up: the three most neglected areas on V11: > Rear drive: far right side needle cage. > Sidestand fasteners, both, but especially the high torque large bolt. > Charging system failure (ungrounded regulator, melting 30 amp fuse, broken stator wires). Putting "Rear drive: far right side needle cage.: on my list now. Thanks docc for the reminder. I just did brake fluid flush on my '02 clutch/brakes. The '03 is now saying "Hey, what about me!" 4
Art Posted June 1, 2023 Author Posted June 1, 2023 My history in electronics repair leads me to believe that sensors, or any electrical components last longer with good electrical connections. Intermittent connections cause voltage spikes and current surges. I'll be unplugging connectors and shooting in some cleaner. Worth noting that my experience goes back to the days of LUCAS wiring and warm beer. 1 3
LaGrasta Posted June 2, 2023 Posted June 2, 2023 Great thread, our list of items of which to focus for long lasting miles of riding. Thankfully, I do love to tinker! 5
