mikev Posted June 16, 2023 Author Posted June 16, 2023 On 6/16/2023 at 11:48 AM, docc said: My last ones came from here: https://www.mgcycle.com/index.php?main_page=product_info&products_id=94 Expand Yes, thanks. I've back ordered a couple of those. 1
mikev Posted June 16, 2023 Author Posted June 16, 2023 these were pointed out to me by andrew @mgcycle as replacement intake sleeve which is in stock https://www.mgcycle.com/index.php?main_page=product_info&products_id=42 1
docc Posted June 16, 2023 Posted June 16, 2023 On 6/16/2023 at 3:03 PM, mikev said: these were pointed out to me by andrew @mgcycle as replacement intake sleeve which is in stock https://www.mgcycle.com/index.php?main_page=product_info&products_id=42 Expand I checked my records and those are the actual ones I got (Part Number: 01114390). Cheaper now than they were last year . . . .
mikev Posted November 30, 2023 Author Posted November 30, 2023 My winter project is hopefully to complete a reinstall of the airbox on my V11. Having some trouble finding parts that go from throttle body to air box, specifically #19 in attached image. #4 are still for sale on mgcycle. Anyone have a source for decent used parts possibly? If not I may have to "modify" whats there somehow to make a tight connection to the airbox.
MartyNZ Posted November 30, 2023 Posted November 30, 2023 On 11/30/2023 at 8:44 PM, mikev said: My winter project is hopefully to complete a reinstall of the airbox on my V11. Having some trouble finding parts that go from throttle body to air box, specifically #19 in attached image. #4 are still for sale on mgcycle. Anyone have a source for decent used parts possibly? If not I may have to "modify" whats there somehow to make a tight connection to the airbox. Expand Item 19 is important. The shape improves airflow into the throttle body. It's called "velocity stack", "bellmouth", or "trumpet", and you should try hard to get the right parts. Have you checked to see if they are wedged into whatever gravel strainer pod filters you had before? 1
mikev Posted November 30, 2023 Author Posted November 30, 2023 On 11/30/2023 at 9:31 PM, MartyNZ said: Have you checked to see if they are wedged into whatever gravel strainer pod filters you had before? Expand This is what I have on it currently. Looks like one piece vs 2 in diagram. Also, airbox end doesn't flair out to seal against the box, so I think its not correct.
pete roper Posted November 30, 2023 Posted November 30, 2023 Does it look like it has been cut/chopped/modified in any way? If not I'd think it's probably the original part. I can't remember exactly how they seal to the box. Usually it's some sort of lipped flange but if push comes to shove you could simply install the box and then seal around them with silastic. Not ideal but a zillion times better than pods. 2
mikev Posted November 30, 2023 Author Posted November 30, 2023 doesn't look modified unless they did a really neat job of it
Lucky Phil Posted November 30, 2023 Posted November 30, 2023 On 11/30/2023 at 10:37 PM, pete roper said: Does it look like it has been cut/chopped/modified in any way? If not I'd think it's probably the original part. I can't remember exactly how they seal to the box. Usually it's some sort of lipped flange but if push comes to shove you could simply install the box and then seal around them with silastic. Not ideal but a zillion times better than pods. Expand Yea they just have a full circle grommet style seal on the airbox Pete and the trumpet inserts from the airbox and connects to the T/B. The rubber seals are still available I think but the trumpets are hard to find, new anyway. Phil 1
Lucky Phil Posted November 30, 2023 Posted November 30, 2023 On 11/30/2023 at 10:49 PM, mikev said: doesn't look modified unless they did a really neat job of it Expand No it's modified. Had the bell cut off it to fit the pod filter at some point. https://www.officine08.com/p69547_intake-joint-moto-guzzi-1100-sport-i-e-air-filter.html Airbox seal https://www.stein-dinse.com/en/moto-guzzi-rubber-air-filter-short-1100-sport-i-e-corsa/item-1-1127372.html Phil 1 2
pete roper Posted December 1, 2023 Posted December 1, 2023 Oooh. Lookee! https://tlm.nl/moto-guzzi-triumph/us-01114400-a-used-inlaatkelk-v11-1100-sport-a Two in stock. Get 'em while they're hot! 2 1
pete roper Posted December 1, 2023 Posted December 1, 2023 Oh, they have a couple of brand new ones too. https://tlm.nl/moto-guzzi-triumph/011144000000-inlaatkelk-v11-uit-produktie 1 1
docc Posted December 1, 2023 Posted December 1, 2023 I see two available, used, from TLM/The Netherlands eBay listings: https://www.ebay.com/itm/134663701995 1
Lucky Phil Posted December 1, 2023 Posted December 1, 2023 Here's a tip, anything made of rubber buy as spares when you can and treat them with preservative and a clip lock bag and store them away out of the light. Rubber parts are a PITA to replicate or find an alternative to. I have my stash. Phil 1
