docc Posted December 1, 2023 Posted December 1, 2023 13 minutes ago, Lucky Phil said: Here's a tip, anything made of rubber buy as spares when you can and treat them with preservative and a clip lock bag and store them away out of the light. Rubber parts are a PITA to replicate or find an alternative to. I have my stash. Phil Ah, yeah, rubber preservative/restorative: 2
gstallons Posted December 1, 2023 Posted December 1, 2023 8 hours ago, Lucky Phil said: Here's a tip, anything made of rubber buy as spares when you can and treat them with preservative and a clip lock bag and store them away out of the light. Rubber parts are a PITA to replicate or find an alternative to. I have my stash. Phil I haven't heard that term in a LOOOONG time !
mikev Posted December 1, 2023 Author Posted December 1, 2023 Thanks. I ordered some parts. Curious that the airbox seal isn't illustrated on the diagram.
docc Posted December 1, 2023 Posted December 1, 2023 4 hours ago, mikev said: Thanks. I ordered some parts. Curious that the airbox seal isn't illustrated on the diagram. Isn't that the #4 GU37114806 "hose?"
GuzziMoto Posted December 1, 2023 Posted December 1, 2023 5 minutes ago, docc said: Isn't that the #4 GU37114806 "hose?" Pretty sure #4 is the adapter that connects #19 to the throttle body, not the part that connects it to the airbox. 1
docc Posted December 1, 2023 Posted December 1, 2023 3 minutes ago, GuzziMoto said: Pretty sure #4 is the adapter that connects #19 to the throttle body, not the part that connects it to the airbox. Ah, yes, definitely! I had not realized there is a separate "collar" to connect to the back of the throttle body. Thanks, @GuzziMoto!
Lucky Phil Posted December 1, 2023 Posted December 1, 2023 3 hours ago, GuzziMoto said: Pretty sure #4 is the adapter that connects #19 to the throttle body, not the part that connects it to the airbox. No it's the airbox sealing sleeve. Phil
mikev Posted December 1, 2023 Author Posted December 1, 2023 4 minutes ago, Lucky Phil said: No it's the airbox sealing sleeve. So the diagram has their positions reversed? ok, well I got an extra pair of them I guess
Lucky Phil Posted December 1, 2023 Posted December 1, 2023 2 minutes ago, mikev said: So the diagram has their positions reversed? ok, well I got an extra pair of them I guess Yep. The rubber sleeve that connects the trumpet to the TB is in the previous parts manual drawing. Phil
Speedfrog Posted December 1, 2023 Posted December 1, 2023 @docc & @Lucky Phil are right. @mikev #4 in the diagram you posted is the sleeve/seal connecting the air intake tube to the airbox. The sleeve connecting the air intake to the TB can be found in the TB diagram - #16 1
Lucky Phil Posted December 1, 2023 Posted December 1, 2023 Parts manuals. Here;s another version of the parts manual. Has anyone ever seen item 19 fitted on a Guzzi V11 Sport? It's not the part number for the clamp that connects the trumpet sleeve to the throttle body either. Parts manuals, they can be misleading sometimes. 1
Speedfrog Posted December 1, 2023 Posted December 1, 2023 That clamp (#21) shouldn't be there, probably a remnant of earlier models... If you look at the drawing posted earlier, it's not there. 1
docc Posted December 1, 2023 Posted December 1, 2023 14 minutes ago, Speedfrog said: That clamp (#21) shouldn't be there, probably a remnant of earlier models... If you look at the drawing posted earlier, it's not there. Welldone, @Speedfrog! Combining those two diagrams is tricky. On the airbox diagram, it does appear my 2000 Sport has the #19 "trumpet" from the airbox to the back of the throttle body with #4 sealing the trumpet to the airbox. No #21 clamp. Then, on the throttle body diagram, my Sport uses the #16 "collar" and clamp #15 to connect the airbox trumpet to the back of the throttle body. [The #14 rubber intake to the #8 intake manifold in front of the throttle body is another matter, entirely.] 2
Lucky Phil Posted December 1, 2023 Posted December 1, 2023 23 minutes ago, Speedfrog said: That clamp (#21) shouldn't be there, probably a remnant of earlier models... If you look at the drawing posted earlier, it's not there. Problem with that theory is the 99-2000 parts manual shows no clamp and the 02-2007 I have shown has a clamp that's never been fitted to any model as far as I can see. So it's not an outdated carry over from a previous manual. The original image posted may be an even later iteration or amendment to a mistake in the manual. This is why in the aviation world the parts manual was never allowed to be a legal reference for the assembly of aircraft components, it was a part number sourcing reference only. Never to be used to demonstrate assembly order. Phil 1
Speedfrog Posted December 1, 2023 Posted December 1, 2023 13 minutes ago, Lucky Phil said: Problem with that theory is the 99-2000 parts manual shows no clamp and the 02-2007 shown has a clamp thats never been fitted as far as I can see. So it's not an outdated carry over from a previous manual. Not a "theory" per se Phil, only a supposition... Admittedly, I didn't scour all the different versions of the parts catalog for the 1100 big block engine.
