I've done a search and read over the FAQs.  I thought there was a diagram that indicates which relay matched to circuit.
Specifically looking for the relay controlling the ignition circuit.  Thanks.
No relay for the ignition switch, IIRC.
There is some good circuit prints around here, CRW.
Cheers Tom.
Expand
sorry, I meant spark plug circuit.
Relays front to back:
1. START (5 Pin Relay)
2. LIGHTS (4 Pin Relay. 5 Pin OK)
3. NEUTRAL/SIDESTAND (4 Pin Relay. 5 Pin OK)
4. ECU (4 Pin Relay. 5 Pin OK)
5. FUEL/COIL/INJECTION (4 Pin Relay. 5 Pin OK)
  • Thanks 2
Then #5 if you're not getting spark or fuel.  That one seems to be most trouble prone for me.
