Tomchri Posted August 15, 2023 Author Posted August 15, 2023 Thanks Marty, wild quess now is down to Termignoni . Cheers Tom. 1
Tomchri Posted September 21, 2023 Author Posted September 21, 2023 It says dryk ventil, ( pressure valve), wondering what purpose ?And the sensor in the left valve cover? Same temp sensor as in the filter box on the V11.Cheers Tom. Sent fra min SM-S906B via Tapatalk 1
audiomick Posted September 22, 2023 Posted September 22, 2023 Hi Tom. I don't know anything for sure, but... In the German forum I found a number of references to the temp. sensor in the valve cover. It seems the Quota and some Californias had that as well, and it seems to be for motor temperature, perhaps one of two temperature sensors. The pressure valve has "100 kPa" written on it. That is "only" one Bar. Where is it exactly? With that value, it can hardly be fuel pressure. As far as I know, that should be more like 3 or 4 Bar, shouldn't it? EDIT: I think I've found the pressure thing. It looks like it is not a valve but rather a pressure sensor. Part #14 here: https://www.stein-dinse.biz/etkataloge/etkataloge.php?l=de&m=227&t=5671&c=W The disturbing news: https://www.stein-dinse.com/de/search.html?grp=&searchStr=29727061 and the good news, the alternative part: https://www.stein-dinse.com/de/search.html?grp=&searchStr=200516001 Slight price difference.... 1 2
MartyNZ Posted September 22, 2023 Posted September 22, 2023 10 hours ago, Tomchri said: It says dryk ventil, ( pressure valve), wondering what purpose ? Cheers Tom. Sent fra min SM-S906B via Tapatalk The Sport 1100i manual says "Absolute pressure transducer. This transducer is powered by the electronic control centre and gives information about the absolute pressure in the air filter box. This transducer is connected to the filter box through a small pipe. Its output signal will produce a correction signal as function of the barometrical pressure". On the V11 there is a pressure transducer built into the ECU. 4 1
Tomchri Posted September 22, 2023 Author Posted September 22, 2023 Again thank you Marty, sort of my thoughts to. I need to get manuals in ingliissh. Leak down test today, amasingly good for 95000km, 3-4% tested with 2 Sun test maschines. Another exelent friday, IPA time here. Thanks for the V11 forum. Cheers Tom. Sent fra min SM-S906B via Tapatalk 4
Tomchri Posted September 23, 2023 Author Posted September 23, 2023 Simple reason for clutch slippage. 7.12mm plates. Cheers Tom. Sent fra min SM-S906B via Tapatalk 3
audiomick Posted September 23, 2023 Posted September 23, 2023 1 hour ago, Tomchri said: Simple reason for clutch slippage. 7.12mm plates. That's supposed to be more like 8 mm or so, isn't it?
Tomchri Posted September 24, 2023 Author Posted September 24, 2023 Correct, new ones 8.4mm. Cheers Tom. 1
audiomick Posted September 24, 2023 Posted September 24, 2023 I am always pleased to find a clearly identifiable cause for a problem. Makes it easier to fix, and one knows for sure that the fix really is a fix.
Tomchri Posted November 4, 2023 Author Posted November 4, 2023 Sounds about right. New clutch in, connect clutch wire, ææh NO clutch. Ended up with a 3,1mm long SS rod inside the metal cylinder that pushes the rod. Yes larger clutch plates, not 100% original. But yes bike in 2gear, small plier in u joint, clutch handle in, YES. Cheers Tom. Sent fra min SM-S906B via Tapatalk 4
audiomick Posted November 5, 2023 Posted November 5, 2023 On 11/4/2023 at 2:09 AM, Tomchri said: ... ææh NO clutch. For the sake of clarity: I gather you mean it didn't release because the new clutch is thicker, and the system didn't provide enough reach without the 3-and-a-bit extra from the spacer?
Tomchri Posted November 5, 2023 Author Posted November 5, 2023 19 hours ago, audiomick said: For the sake of clarity: I gather you mean it didn't release because the new clutch is thicker, and the system didn't provide enough reach without the 3-and-a-bit extra from the spacer? Correct. Cheers Tom. 1
Tomchri Posted April 4, 2024 Author Posted April 4, 2024 Finished, now weather and tuning. ECU been a trip to C Jefferies. We like clean ladies.Cheers Tom. Sent fra min SM-S906B via Tapatalk 8
