Lucky Phil Posted August 12, 2023 Posted August 12, 2023 Noticed Mass lists these. Far better design than the Mistral. Looks like a Stucchi copy. https://www.massmoto.it/prodotto/collettori-secondari-x-pipe-2-in-2-in-acciaio-inox-aisi-304-moto-guzzi-v11-sport-le-mans/ Phil 2
Lucky Phil Posted August 12, 2023 Author Posted August 12, 2023 I've got a feeling this might be closer to the production version docc. You'd need to check with them. 1
Anders Posted August 16, 2023 Posted August 16, 2023 On 8/12/2023 at 2:50 AM, docc said: I think that is the crossover part of the system they built for me.I wanted as much torque from 3000-5000rpm.I asked for a system with 42mm ID all the way through from cylinder to siilencers.More or less a copy of the stainune system.I thought that would bring good velocity,and then a big joint part where there could be lots of scavenging. I haven't fit it on the bike yet though. I don't know if they sell that system they designed for me,i think they do. 1
Anders Posted August 16, 2023 Posted August 16, 2023 On 8/12/2023 at 3:19 AM, Lucky Phil said: I've got a feeling this might be closer to the production version docc. You'd need to check with them. https://www.caferace.it/eng/articles?filtri=ok&id_cat=91&id_sottocat1=&id_sottocat2=&id_sottocat3=&nome_cerca=&marca_cerca=&promozione=&categoria_cerca=&adatto_a_cerca=Moto+Guzzi+V11+Le+Mans&marche_cerca=MASS&materiale_cerca=&colore_cerca=&Omologato_cerca=&ordinamento= I think that part may be avaliable at www.caferace.it If you are lucky. 1
