Hello,
Does anyone have a pair of MPH risers for sale by any chance?
I have been looking for a uk Stockist but cant find one so far.
To confirm I am looking to do a deal on a pair that will fit my 2007 registered V11 Le Mans, I like the idea of being able to use the existing Moto Guzzi bars and keep the same handle bar angle which they will provide.
Regards,
Formula Alfa.
6 hours ago, Formula Alfa said:
Hello,
Regards,
Formula Alfa.
MPH still sells the riser kits, I bought my 1st set of MPH risers in 2004, the 2nd set in 2022. The only changes according to the kit is an eagle emblem instead of MPH scribed into the aluminum. The kit has always came with new steel braided hydraulic clutch and brake lines. The hydraulic clutch is tight but can be made to work, the fix is to order one for a Centauro, which is longer and makes the kit much easier to install. :sun:
  • Like 3
Ok, Speedfrog, Joe,
Thanks for your replies, that also sounds like a good tip Joe, to order the centauro clutch line.
I shall make some enquiries.
Regards,
Formula Alfa.
