I am looking to fit a SW-Motech tank bag to my 1998 MG Centauro but they do not list a mounting ring that fits. Apparently, the fuel filler ring is shared with the V11. I wonder whether anyone here has found a mounting ring that fit their V11?
Hi Brian, I have been an SW Motech twice this year for my Honda. No issue with the products, but the delivery times to the UK? Not impressive to say the least.
SW-MOTEC was excellent in terms of speed of response, even if that response was disappointing.
My V11 Le Mans had an SW-Motec Evo ring on it when I bought it. I can't measure anything, I'm afraid, or look for a number, as I've already passed it on to someone else.
I did have a look on the SW-Motec site the other day when I saw your first post the first time. I thought it was there that I had seen diagrammes of how the measure the rings, but it might have been Hepco-Becker. Anyway, you're looking for "universal ring", I think, and some way definition of the diameter and number of screw holes. :huh2:
Indeed, but they have nothing in a tank mount ring that is undrilled, so I have ordered a tail bag mount which I  will cut to fit, I hope.🤪
The V11 Sport also has the same fuel tank filler ring as Aprilias of the same vintage iirc...
It's the " vintage" thing that appears to be the problem. Do you know if the Tuono one would fit?
Cross references for V11 Sport fuel tank cap:
Aprilia '98-'03 RSV Mille 1000 & '02-'05 Tuono.
Givi Tanklock tank ring p/n:   BF02
SW-Motech Evo tank ring p/n:   TRT.00.640.17500/B
SW-Motech Pro tank ring p/n:   TRT.00.787.17500/B
SW-Motech Ion tank ring p/n:    TRT.00.475.17500/B
Check out this topic:  https://www.v11lemans.com/forums/topic/22036-anyone-successfully-use-one-of-those-quick-release-tank-bag-adapter-rings/
Edit: I removed the Triumph cross references for clarity and because, although the Triumph x-ref. is valid for the Givi Tanklock ring, it might not be for the sw-motech rings.
I also added the SWM Ion tank ring for those interested in the Ion line of tank bags.
  • Thanks 2
Aprilia '98-'03 RSV 1000 & '02-'05 Tuono, also Triumph Speed Triple 1050, Tiger 1050, Sprint ST 1050
Check this topic:  https://www.v11lemans.com/forums/topic/22036-anyone-successfully-use-one-of-those-quick-release-tank-bag-adapter-rings/
Perfect!  Thank you.
This is exactly what I was looking for.
I have found it available through a Canadian distributor and have ordered it through the local retailer.
I'll post pictures of the fitment.
