I am looking to fit a SW-Motech tank bag to my 1998 MG Centauro but they do not list a mounting ring that fits. Apparently, the fuel filler ring is shared with the V11. I wonder whether anyone here has found a mounting ring that fit their V11?
Hi Brian, I have been an SW Motech twice this year for my Honda. No issue with the products, but the delivery times to the UK? Not impressive to say the least.
Expand
SW-MOTEC was excellent in terms of speed of response, even if that response was disappointing.
My V11 Le Mans had an SW-Motec Evo ring on it when I bought it. I can't measure anything, I'm afraid, or look for a number, as I've already passed it on to someone else.
I did have a look on the SW-Motec site the other day when I saw your first post the first time. I thought it was there that I had seen diagrammes of how the measure the rings, but it might have been Hepco-Becker. Anyway, you're looking for "universal ring", I think, and some way definition of the diameter and number of screw holes. :huh2:
Indeed, but they have nothing in a tank mount ring that is undrilled, so I have ordered a tail bag mount which I  will cut to fit, I hope.🤪
Expand
The V11 Sport also has the same fuel tank filler ring as Aprilias of the same vintage iirc...
Expand
It's the " vintage" thing that appears to be the problem. Do you know if the Tuono one would fit?
Cross references for V11 Sport fuel tank cap:
Aprilia '98-'03 RSV Mille 1000 & '02-'05 Tuono.
Givi Tanklock tank ring p/n:   BF02
SW-Motech Evo tank ring p/n:   TRT.00.640.17500/B
SW-Motech Pro tank ring p/n:   TRT.00.787.17500/B
SW-Motech Ion tank ring p/n:    TRT.00.475.17500/B
Check out this topic:  https://www.v11lemans.com/forums/topic/22036-anyone-successfully-use-one-of-those-quick-release-tank-bag-adapter-rings/
Edit: I removed the Triumph cross references for clarity and because, although the Triumph x-ref. is valid for the Givi Tanklock ring, it might not be for the sw-motech rings.
I also added the SWM Ion tank ring for those interested in the Ion line of tank bags.
  • Thanks 2
Aprilia '98-'03 RSV 1000 & '02-'05 Tuono, also Triumph Speed Triple 1050, Tiger 1050, Sprint ST 1050
Check this topic:  https://www.v11lemans.com/forums/topic/22036-anyone-successfully-use-one-of-those-quick-release-tank-bag-adapter-rings/
Expand
Perfect!  Thank you.
This is exactly what I was looking for.
I have found it available through a Canadian distributor and have ordered it through the local retailer.
I'll post pictures of the fitment.
