thelonewonderer Posted October 25, 2023 Posted October 25, 2023 Hello everyone. My 2003 V11 Sport sat for over a year due to a lot of traveling for work. I stupidly forgot to put a stabilizer in the tank, which led to the fuel going bad, as well as the fuel pump. I drained the fuel, then added more, replaced the fuel pump, and put in a brand-new Yuasa battery that I got from Pro Italia in Glendale. After getting the bike back together, it won't start. No lights on the dash (neutral, oil pressure), and the fuel pump doesn't engage. So, it seems I'm not getting any power from the battery. The battery tests fine, and when I plug it into the trickle charger, the green storage light blinks. I've checked the fuse and any connections I could have messed up along the way, but everything seems fine. I'm not sure what to do next. I'm looking forward to your help, as everyone here has always guided me in the right direction over the years. Thank you.
LaGrasta Posted October 25, 2023 Posted October 25, 2023 That fact you have zero electrics, but the battery is good, it can really only be key, fuse, or battery cable. 2
guzzigary Posted October 25, 2023 Posted October 25, 2023 Check you haven’t missed reattaching one or more cables to the new battery. 7
Lucky Phil Posted October 25, 2023 Posted October 25, 2023 37 minutes ago, guzzigary said: Check you haven’t missed reattaching one or more cables to the new battery. Yes easy to miss a cable connection on the v11. Phil 2
thelonewonderer Posted October 26, 2023 Author Posted October 26, 2023 Thank you, everyone. I should have said this before: Pro Italia also installed the battery. I rode the bike home with no problems. A day or two later, the fuel pump went out. After replacing that was when the electrical problem arose. I'll remove the battery and re-install it. I've already changed the fuse. 1
docc Posted October 26, 2023 Posted October 26, 2023 Yes, look deep into the well for a ring terminal that got left off from either the positive or negative terminal stacks. So very common. 3
80CX100 Posted October 26, 2023 Posted October 26, 2023 Any possibility that the troublesome clutch switch bullet connectors left of the head stock or some of the relays came loose while you were working around the tank & battery? 1
audiomick Posted October 26, 2023 Posted October 26, 2023 1 hour ago, thelonewonderer said: I've already changed the fuse. Did you test it? Was it really blown? If so, why? There is a problem somewhere. If not, that was obviously not the problem. I'd be suspecting bad connections somewhere. Either corrosion through standing around, or having missed a cable when re-installing the battery, as has been mentioned, or some other cable (like the clutch switch connedtors), that may have been somehow involved in any work done on the bike. 1
thelonewonderer Posted October 26, 2023 Author Posted October 26, 2023 Thanks again, everyone. I'll be back at it again tomorrow. I can tear apart the engine, forks, transmission, etc., and rebuild them to spec, but when it comes to the electrical side, I'm an idiot.
thelonewonderer Posted October 26, 2023 Author Posted October 26, 2023 4 hours ago, audiomick said: Did you test it? Was it really blown? If so, why? There is a problem somewhere. If not, that was obviously not the problem. I'd be suspecting bad connections somewhere. Either corrosion through standing around, or having missed a cable when re-installing the battery, as has been mentioned, or some other cable (like the clutch switch connedtors), that may have been somehow involved in any work done on the bike. It wasn't blow, but as I mentioned, electricity is foreign to me. I changed it out of caution. I have plenty of fuses lying around. I know enough to know that if the fuse wasn't blown, it's probably an issue with some connection.
LaGrasta Posted October 26, 2023 Posted October 26, 2023 I wonder if it's grounding out, maybe positive to the frame?
Tomchri Posted October 26, 2023 Posted October 26, 2023 And the main ground at the back of the tranny ? Cheers Tom.
docc Posted October 26, 2023 Posted October 26, 2023 Recently, we had the opportunity to troubleshoot two different V11 with this behavior. On one, the Run Switch had been toggled off, un-noticed. [edit: as @p6x points out, this condition allows the lights on, but not fuel/ignition.] The other was not in neutral and would not power on with the sidestand down. So, be certain the Run Switch is on and the bike is in neutral with the Neutral Light aglow. If is not, sit astride and attempt the start with the stand up and the clutch pulled in . . . 2
p6x Posted October 26, 2023 Posted October 26, 2023 15 minutes ago, docc said: On one, the Run Switch had been toggled off, un-noticed. The OP stated when he switches the ignition, the bike remains dead; no light on the dash, no fuel pump noise; with the run switch in off position, you still get the lights and the fuel pump. 2
