Hello everyone
how do you guys call that long bolt that goes trough the alternator cover and on one side it is attached the side stand mount ?
where can I find one ?
The one circled in red or the bigger one at the top left of the image?
Top left thank you :-)
Alright, @arveno:
3 - "screw" GU30432801
4 - "Special washer"  GU95021114
8 -  "Washer"  GU95100120
Neither the Parts catalog nor the Workshop Manual shows any dimensions.
[ Also, note that it torques to 70-75 Nm ! ]
Foot-rests--Lateral-stand-MOTO-GUZZI-MOT
Looks to me to be a bit of a "special" item. :huh2:
30432801_s.jpg?1668313914101
The picture is from Stein-Dinse, where it is quite expensive.
https://www.stein-dinse.com/de/staenderschraube-daytona-2-serie/item-2-1117062-30432801-.html
Wendel apparently has one (but only one...) for a lot less money. The question is, what would it cost to have it sent to where you are. :huh2:
https://wendelmotorraeder.de/schraube_gu30432801-p-1009294.html?ref=expl
EDIT: PS on the Wendel page, underneath the price, it says
"(statt 39,90 € ehemaliger VK)"
which means "instead of the original list price of €39.90".
So even though the Stein-Dinse price seems high, it is apparently not exorbitant.
Yes, that bolt is very specific. Along with one of the two "washers."
I am hoping someone has the whole Rube Goldberg sidestand assembly in a pile and could measure the parts . . .
38 minutes ago, arveno said:
Cadre cycle has one -:) 8 bucks ah ah
thanks
Order today = June delivery? :huh:
  • Haha 2
 Bolt Dimensions
  14mmX1.5 pitch
  Thread length 28mm.
  I may have one in my stash and will look  this afternoon.
  Paul B:bier:
  • Thanks 2
3 hours ago, paulnaz said:
 Bolt Dimensions
  14mmX1.5 pitch
  Thread length 28mm.
  Paul B:bier:
Any insights on the washers (especially the "special" washer)?
External tooth lockwasher, is the only washer I have. No clue what the second one is.
 I did find an extra bolt in my stash.
Paul B:bier:
Once again from the Stein-Dinse catalogue:
https://www.stein-dinse.biz/etkataloge/etkataloge.php?l=de&h=MG&m=220&t=5368
#4 on the diagram, GU 95021114. The part offered for sale is apparently after-market, not original Guzzi.
95021114_g.jpg?1668321814909
https://www.stein-dinse.com/de/zahnscheibe-nml/item-2-1310507-95021114-.html
#8 GU 91120620, "spacer washer". This is an apparently original Guzzi replacement for GU 95005320
91120620_g.jpg?1668321681630
https://www.stein-dinse.com/de/distanzscheibe/item-2-1302017-91120620-.html
No dimensions there either, unfortunately.
The outside diameter could be guessed from the photo, I reckon. The thickness, perhaps more critical when they call it a "spacer washer", might be harder. Going by the picture, I'd guess something like 4mm.
The bolt would likely bottom in the blind hole without a spacer standing it off. A pair of normal flat washers "might " do it, but getting the 70-75 Nm is apparently important to expect that little leg to hold up our heavy girl . . .
Just a reminder for everyone to check that torque and make sure the smaller (red circled) fastener hasn't wiggled itself loose. When that one fails, it takes a bit of the sump spacer with it.
  • Thanks 2
