mikev Posted February 22 Posted February 22 Does anyone have any recommendations on bar end weights for my 2000 v11? I am sort of restoring it to original, and have completed getting the stock air box re-installed. Sounds nicer. Its cold here and roads are salty so haven't gotten a proper ride in yet. Now want to rid myself of the bar end mirrors. Always bumping into the wood pile in garage. Thinking of the "standard" mirrors on MG Cycle and need some bard end weights Any recommendations appreciated.
Lucky Phil Posted February 23 Posted February 23 22 hours ago, mikev said: Does anyone have any recommendations on bar end weights for my 2000 v11? I am sort of restoring it to original, and have completed getting the stock air box re-installed. Sounds nicer. Its cold here and roads are salty so haven't gotten a proper ride in yet. Now want to rid myself of the bar end mirrors. Always bumping into the wood pile in garage. Thinking of the "standard" mirrors on MG Cycle and need some bard end weights Any recommendations appreciated. Congratulation on re fitting the airbox, good move. The crem de la crem of mirrors are Rizomas from my experience and congrats again upon ridding yourself of the Mickey Mouse ear mirrors. Rizomas come in various styles but I run these. Bar end weights. Standard are best. Phil 3
audiomick Posted February 23 Posted February 23 Thanks for the picture of the Rizomas @Lucky Phil. I'm looking for some mirrors for the V35 Imola, and the ones in your photo might be an option now I've seen the photo.
activpop Posted February 23 Posted February 23 Now that you called them Mickey Mouse @Lucky Phil, I have to change them. 1
Lucky Phil Posted February 23 Posted February 23 9 hours ago, audiomick said: Thanks for the picture of the Rizomas @Lucky Phil. I'm looking for some mirrors for the V35 Imola, and the ones in your photo might be an option now I've seen the photo. You can buy Chinese "branded" Rizoma knock offs for about a 1/4 of the price from western re sellers and the quality "looks" fine but they suffer from things like the adjustment ball is so tight it's unusable which is a total PITA if you knock one out of adjustment. Tools required. I have them on the RE and must replace them.
mikev Posted February 23 Author Posted February 23 the rizoma website doesnt list V11s - will mirrors for other guzzi models be compatible?
audiomick Posted February 23 Posted February 23 @mikev My V35 Imola and my Breva both have the same thread on both mirrors. That is the critical point. Some manufactureres have right-hand thread on both sides, some have one right-hand and one left-hand. Screw your mirrors off and have a look, and measure the diameter. It is likely to be a fine pitch thread, I think. The mirrors on the Imola are that for certain. On the strength of what you find you should be able to tell if the mirrors from other models or suppliers will fit or not. @Lucky Phil I'm a bit interested in this line of products. Stupidly expensive, but the mirrors are made of polished aluminium. No glass, so nothing to shatter. https://motogadget.com/collections/spiegel-englisch 1
audiomick Posted February 23 Posted February 23 You should be able to find something that fits in the existing thread, or is there no mounting point on your bike?
Lucky Phil Posted February 23 Posted February 23 49 minutes ago, mikev said: the rizoma website doesnt list V11s - will mirrors for other guzzi models be compatible? Just buy the style you want and the adaptors (see my image). Mirrors are pretty much universal. You might need the thread size which I believe is 10mm. Left hand thread one side and right the other. Pitch is 10X1.25. 2
Lucky Phil Posted February 23 Posted February 23 24 minutes ago, audiomick said: @mikev My V35 Imola and my Breva both have the same thread on both mirrors. That is the critical point. Some manufactureres have right-hand thread on both sides, some have one right-hand and one left-hand. Screw your mirrors off and have a look, and measure the diameter. It is likely to be a fine pitch thread, I think. The mirrors on the Imola are that for certain. On the strength of what you find you should be able to tell if the mirrors from other models or suppliers will fit or not. @Lucky Phil I'm a bit interested in this line of products. Stupidly expensive, but the mirrors are made of polished aluminium. No glass, so nothing to shatter. https://motogadget.com/collections/spiegel-englisch I've seen those Mick but considering the cost my rationale is that the only time the reflector breaks is if you drop/crash the bike and if that happens hard enough to break the reflector then the whole mirror is generally junk anyway. Phil 1
docc Posted February 24 Posted February 24 Look at where the two bolts clamp the assembly to the bar and see if the clamp has been turned upside down with the mirror mount on the bottom... 3 1
mikev Posted February 24 Author Posted February 24 thanks - totally missed that - just reversed them. 3
guzzler Posted February 24 Posted February 24 23 hours ago, Lucky Phil said: You can buy Chinese "branded" Rizoma knock offs for about a 1/4 of the price from western re sellers and the quality "looks" fine but they suffer from things like the adjustment ball is so tight it's unusable which is a total PITA if you knock one out of adjustment. Tools required. I have them on the RE and must replace them. I've had the chinese Rizoma rip-offs on mine for a few years now! Apart from the adjustability factor as Phil has mentioned they're ok and work for me. I cant remember the price but it was significantly cheaper than the real deal. Cheers 1
